My 87 PK XL has a shitty fuel tank. OK, its not the worst ive seen, worst ive had but evidence in the carb filter suggests crud. In the SHBL20 carb the circular filter is getting about a quarter of its surface coated in the tank wall crud after a few months. OK, i can take the carb off and clean periodically but its a faff.
So as we know with all after market parts they are never right. I cannot get a NOS PK XL petrol tank. The supposedly exactly the same PK XL tank from beedspeed was a load of crap, the fuel sender hole did not have the locking ring welded on to surface to secure my fuel sender. Second hand XL tanks are all the same as mine, the lining of tank reacting with petrol. Im not going down the route of cleaning the tank in a cement mixer with nuts bolts in, been there, done it, made things worse on my old LD 150. So i want to talk inline filters.
Issues, the distance from tank to carb is a very short run of fuel line on a smally.
I appreciate that having a full tank of fuel dramatically improves the gravity feed of petrol.
Have you tried or can recommend a good inline fuel filter that i could use to solve my cruddy tank issue.
I need something that i can visually inspect, easily remove and clean but will allow a decent flow of fuel to carb. Ive tried a very small inline filter to test the concept but i could clearly see the fuel not getting to carb well for startup. Once the scoot starterd, fuel started sucking through.
Ive had the fuel tap which was shot to a fast flow tap, so thinking about one of the glass types you can visually inspect. I need a 6mm filter fitting whereby the filtering material will allow a decent flow.
Also, where is the best place to position the inline filter? Near the carb, middle of fuel line, top of fuel line. Aware the fuel taps have filters too but from experience they arent great with fine particles.
If you can recommend a gravity feed inline filter id be grateful. Would it also be a good idea with inline filter to remove the carb filter to improve flow?
Thanks all.
