Today I removed the glovebox and installed a u.s.b port that is plug in play on my 2022 300 super hpe. All went well but after I secured glovebox back with all the screws I find that when I push the key to open nothing happens. I cant remove the box now due to the screw that is inside glovebox is not accessible to remove. What do I do? The left knee pad removed and glove box release is not reachable by hand. Any advice would great. Thanks
2015 Sprint 150, 2018 GTS 300
Posts: 894 Location: SoCal |
Posts: 15121 Location: The state of insanity, SoCal |
the glove box lever is misaligned with the latch.
use a length of coat hangar to fish thru the front cover and pop it. when you're reinstalling, using a little piece of that wire to make a hoop and keep the lever in place. then push the hook on the inside of the glove box upward for maximum clearance while you slip it between the lever and the push ring/lock body of the ignition. snap all the screws in and test it BEFORE latching the door, just to be sure.
Positive
greasy125 wrote: the glove box lever is misaligned with the latch. use a length of coat hangar to fish thru the front cover and pop it. when you're reinstalling, using a little piece of that wire to make a hoop and keep the lever in place. then push the hook on the inside of the glove box upward for maximum clearance while you slip it between the lever and the push ring/lock body of the ignition. snap all the screws in and test it BEFORE latching the door, just to be sure. ⚠️ Last edited by Max6200 on UTC; edited 1 time
Max6200 wrote: Forget that. This is categorically imperative that you access the latch through the left knee panel. |
no, he's right. you can access it that way too.
I just prefer to go thru the front because sometimes there's other items there-- horn, abs pump, alarm/afterarket junk-- and it's a tight fit and funny contortion of the hand to get there. different strokes for different folks.
Positive
Thank you all for the suggestions. I tried using a coat hanger through left knee pad but there are so many wires and difficult to see even with a mirror and flashlight. Im afraid of pulling out wires by accident and causing more problems. Can you access the latch through the horn cover? Really? I will check it out in the morning. Thanks again
My dealer is 4hrs away. I was waiting until my 6k service to take it but I only have 2k now. Lol.
I have a front rack so it's kind of a pain to access through the horn cover. Removing and placing it back the front rack all lined up is a challenge for me. OP I hope you have long fingers
greasy125 wrote: no, he's right. you can access it that way too. I just prefer to go thru the front because sometimes there's other items there-- horn, abs pump, alarm/afterarket junk-- and it's a tight fit and funny contortion of the hand to get there. different strokes for different folks. There's no way my big hand could do the left knee panel trick. But YRMV.
Positive
Grumpy Biker
Posts: 5742 Location: Sparks, Nevada, USA |
greasy125 wrote: the glove box lever is misaligned with the latch. use a length of coat hangar to fish thru the front cover and pop it. when you're reinstalling, using a little piece of that wire to make a hoop and keep the lever in place. then push the hook on the inside of the glove box upward for maximum clearance while you slip it between the lever and the push ring/lock body of the ignition. snap all the screws in and test it BEFORE latching the door, just to be sure. OP, if you want some photos for reference, see this Wiki article I wrote after repairing the latch on the ET4. It's not identical to the GT, but you might find the photos helpful to identify the latch mechanism. ET2/ET4: Glovebox Latch Hook Replacement ⚠️ Last edited by caschnd1 on UTC; edited 1 time
Positive
Posts: 46117 Location: Pleasant Hill, CA |
greasy125 wrote: no, he's right. you can access it that way too. I just prefer to go thru the front because sometimes there's other items there-- horn, abs pump, alarm/afterarket junk-- and it's a tight fit and funny contortion of the hand to get there. different strokes for different folks. This the HPE has much more gubbins under the left kneepad. It's the way in on older GTSs though. Use a rubber band on the latch actuator, just as they did in the factory...
Positive
Posts: 1953 Location: Berlin |
Or use a 10mm socket if you don't have a rubber band at hand.
https://vespaforum.de/viewtopic.php?t=24405#p595158
Positive
phaskins wrote: Hmm, I think G knows what he's talking about here, Max. |
Max6200 wrote: Probably so. Many ways to peel an apple. But I am in the not so modern modern Vespa camp. So don't mind me.
Positive
Der Blechfahrer wrote: Or use a 10mm socket if you don't have a rubber band at hand. https://vespaforum.de/viewtopic.php?t=24405#p595158 |
jimc wrote: One can never have too many 10mm wrenches and sockets. |
Update on my glovebox, Today I finally got it open after much frustration. After reading all your advice I finally found the release latch through the left knee pad. My fingers were just long enough to reach after days of trying. Yes the rubber band that vespa uses to hold back release lever had broke so I replaced it with thicker one and now works perfect. Thank you all again for advice. Saved me a lot of $$$ doing it myself rather than the dealer.
Highly Rated
56Nomad wrote: Update on my glovebox, Today I finally got it open after much frustration. After reading all your advice I finally found the release latch through the left knee pad. My fingers were just long enough to reach after days of trying. Yes the rubber band that vespa uses to hold back release lever had broke so I replaced it with thicker one and now works perfect. Thank you all again for advice. Saved me a lot of $$$ doing it myself rather than the dealer. |
Posts: 12897 Location: Fond du Lac, Wisconsin |
jess wrote: And after some amount of time, you will undoubtedly have less of them, because 10mm. Maybe I need a curandera do a sage cleansing of my workshop. |
fledermaus wrote: Maybe I need a curandera do a sage cleansing of my workshop. |
Vespa GTS, BMW C400GT, Ducati Multistrada V4S
Posts: 424 Location: Saint Helena Island, SC |
I just did the same thing. I removed the glove box on my '07 GTS too tap power on the back of the fuse box. Reassembled and the glove box is now stuck.
I have the left knee pad off and the horn cover but don't see the latch. Where is it? Jim |
