So Ivana Tinkle's (Mrs jimc's) LX wouldn't start after a five-week lay-off. It had been somewhat reluctant for some time before that, but a new starter motor had improved it. But now it just wouldn't do anything but 'chug (silence)'.
A new battery didn't improve matters one bit - and the old one measured fine voltage-wise. So up on the lift it went, to check valve clearances. The exhaust was quite tight (less than 0.1mm) - and I found that the lock-nut on the adjuster was very stiff right at the point where it needed to be tightened a bit more. So that was the cause of the tight valve - the locknut had appeared to be snugged down when in fact the adjuster was still capable of some movement.
The spark plug was pretty sooty, mainly from all the duff start attempts, so a new one went in.
And now it's purring again, better than it's been for ages!
That tight locknut was a new one for me - perhaps it might explain some of the other 'hard start' reports.
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
Interesting. I'm assuming the threads are worn. Can a adjuster stud be replaced without disassembling the cylinder head? I might want to order a spare stud and lock nut to have on hand.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
So you put the twinkle back into Ivanka. Very nice.
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
Well done. It's always nice when you finally get it figured out.
[ Time: 0.0079s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
