Wed, 15 Feb 2023 05:30:29 +0000
1979 p200
1979 p200
Wed, 15 Feb 2023 05:30:29 +0000 quote
Hi I am in need of a front fork assy for a 2015 gts300 super. Is there a year range that will fit this bike? From what little that I have found, it seems like 2016 to 2018 125-300 are the same? Can anyone confirm what other model forks that would work?
Thx
Wed, 15 Feb 2023 16:52:05 +0000
Wed, 15 Feb 2023 16:52:05 +0000 quote
Moved to GD to allow replies.
Wed, 15 Feb 2023 19:41:43 +0000
Wed, 15 Feb 2023 19:41:43 +0000 quote
I'm out
Wed, 15 Feb 2023 20:23:48 +0000
Wed, 15 Feb 2023 20:23:48 +0000 quote
rdhood wrote:
It's not a fork, therefore it is not a fork assembly. It is a steering column with an attached shock. Are you changing the whole steeering column, or just the shock?
that just semantics posturing. in common parlance everybody in the scooter community calls it a fork. you knew what they were talking about.
Wed, 15 Feb 2023 21:02:25 +0000
Wed, 15 Feb 2023 21:02:25 +0000 quote
I'm out
Wed, 15 Feb 2023 21:03:33 +0000
Wed, 15 Feb 2023 21:03:33 +0000 quote
'15~'17 (or perhaps late '14 to early '18) some bikes had ESS so the fork will be different with the "bent" suspension arm.
to my knowledge, structurally, the frame remained unchanged so you could always snap in just about any fork from the earlier lines.
but SIP lists just a bare tube if yours is bent and you need to replace it.
Wed, 15 Feb 2023 21:19:49 +0000
Wed, 15 Feb 2023 21:19:49 +0000 quote
rdhood wrote:
It's not "semantic posturing". He's not going to be able to find what he wants if he doesn't even know what to call it. Way to be an a........
O RLY?
google search terms: 2015 vespa front fork
2nd hit gives me this:
https://www.scooterwest.com/vespa-gts-300ie-abs-ess-front-fork-2015-2017.
so basically, an industry leader in parts supply for modern vespas in the US calls it a fork.
call it a rotatornator dowangus for all I care, but don't front like somebody isn't going to be able to find what they need using a commonly known and used sobriquet.
Thu, 16 Feb 2023 14:02:17 +0000
1979 p200
1979 p200
Thu, 16 Feb 2023 14:02:17 +0000 quote
Thanks greasy
  DoubleGood Design
[ Time: 0.0261s ][ Queries: 4 (0.0057s) ][ Debug on ][ 276 ][ Thing Two ]
