Hello all,
Recently purchased an LX50 2 stroke having always had old Land Rovers and have absolutely loved it: very little maintenance (compared to a Landy); great fuel consumption and total smile-factor.
Previous (and only) owner had derestricted, so it did 45mph ish and generally ran really well.
However, original exhaust well past its best and blew a hole: time to replace.
Ended up going for a technigas original pro, as wanted to keep as factory look as possible.
This meant deleting the SAS system that feeds into the exhaust (no problem thanks to threads on here already)
Exhaust fitted perfectly; was pre-derestricted by seller (removed 'cone'); Vespa running like a dream with a bit more poke.
However, now major problems!
Vespa conked out downhill at nearly WOT near 40mph; pushed home. Started at home perfectly; rode around to check all fine. Rode to work this AM, all fine, no hesitation.
Rode back home today, same again! Conked out downhill. Now will not start and have a flat battery (but won't start on the kick either.)
Spark plug a healthy chocolate brown; plenty of fuel and 2 stroke oil.
I am thinking new exhaust potentially requires up-jetting? Running too lean at top end? But, I thought previous owner's mechanic would have done this on original derestriction?
I have another spark plug to put in later today. It runs so well on start up and has been untouched until this point. I know a new exhaust changes this slightly but didn't think I would have to make carb changes; it's not a sports exhaust!
Any helpful advice much appreciated- not sure of any Vespa people here in deepest Cornwall to even take it to and hoping I can sort by myself!
Dom
