Now just how reliable are the auto lube in PX Vespa can l trust it to deliver oil All the time with out any problems ? is it ok to add a bit of oil to the petrol as well ! Just incase of any kind of problems with the feeder not working properly. Do you know of any one doing both with out any problems if so how much is okay to put in the petrol just as a back up protection against any auto lube failure ?? Best foot forward said Jo on ey mo best regards soulboy74 🏴🏴☠️
Posts: 15121 Location: The state of insanity, SoCal |
Incredibly reliable.
If you're running a kit you could add like 1% to the tank but honestly it's probably not needed. |
Jet Eye Master
Posts: 5340 Location: London UK |
greasy125 wrote: Incredibly reliable. If you're running a kit you could add like 1% to the tank but honestly it's probably not needed. |
Jack221 wrote: But must upjet 1% to allow for the displacement of fuel. |
bodgemaster
Posts: 7814 Location: So Cal |
The auto lube mechanism on Vespas is rock solid. 99% of problems are caused by people dicking with it.
Positive
I'm really disappointed that none of the aftermarket smallframe and lambretta cases have included an oil pump.
keeps me looking at retrofitting one... |
oopsclunkthud wrote: I'm really disappointed that none of the aftermarket smallframe and lambretta cases have included an oil pump. keeps me looking at retrofitting one... |
Lambretta did try lubematic on the Cometta in the late 60s, for reasons i dont know, maybe it wasnt reliable or added too much expense to production?!?!
https://www.handh.co.uk/auction/lot/112-1969-lambretta-cometa-75-sl/?lot=55623&sd=1#:~:text=A%20lightweight%20scooter%20it%20was,compared%20to%20larger%20engined%20scooters. |
Grand to hear about the auto lube is bullet proof ! I have been reading about how if it stopped working you are up sht street with out a scooter and off in a dich !! Spring is here in old Briton 🏴 and I am busy learning every thing vespa doing upgrade one at a time so I can see the difference each one does!! So any help from you guys with more experience is most welcome thanks again Gi Briton 🏴 thanks you 👍 best foot forward soulboy74
Posts: 758 Location: UK |
ferriswolf wrote: Lambretta did try lubematic on the Cometta in the late 60s, for reasons i dont know, maybe it wasnt reliable
Positive
After 38 years and over 42000 miles, the auto-lube in my PX 150E is still doing its duty without problems.
The only "problems" with it are leaks of 2T oil, mostly from the plastic oil level sight glass, and failed gaskets under the air box. The sight glass develops cracks either on its nose, where you notice 2T oil on the left side of the floorboard, or around the threaded portion inside the frame. In this case, you find 2T oil puddling inside on the tunnel, which at some point, will even come out of the rear brake pedal cavity under the floorboard. When the gasket under the air box breaks, 2T oil seeps at the rear of the transmission and will leave oil spots on the floor. So, aside from regularly cleaning the mess, and replacing these parts, the system is indestructible, and never fails to provide adequate lubrication at all throttle and speed settings.
Positive
Thanks for your heads up on the oil lube ! Wow 40.000 miles plus and working still with just a few repairs alse where is a good good device gives me peace of mind thinking on 👍 my PX Vespa 125 is still a baby compared to yours with only 2000 miles done from new!! No oils spills yet but Hay what I have noticed is a small amount of oil ish residues down the back side of the engine near where the carb is sitting might be coming out of the air mixture screw grommet is that NORMAL ? Thanks for letting me know where to check ✌️ peace and love soulboy74 🏴
Soul boy 74 wrote: Thanks for your heads up on the oil lube ! Wow 40.000 miles plus and working still with just a few repairs alse where is a good good device gives me peace of mind thinking on 👍 my PX Vespa 125 is still a baby compared to yours with only 2000 miles done from new!! No oils spills yet but Hay what I have noticed is a small amount of oil ish residues down the back side of the engine near where the carb is sitting might be coming out of the air mixture screw grommet is that NORMAL ? Thanks for letting me know where to check ✌️ peace and love soulboy74 🏴 None of these leakages will prevent the motor from getting properly lubed, but will make you top off the oil tank more often. BTW, when you top off the oil tank, only top off to the point where you see the sight glass full, NOT all the way to the top under the oil cap. The plastic coupling between the gas tank and oil tank filling tube is known to crack and leak, as well. I have repeatedly experienced all of these types of leaks in the 38 years I have had this scooter, but they really are only minor annoyances. My engine was overhauled 2000 miles ago, but only because the clutch side seal was allowing gear oil to get burned and make the exhaust smoke; all the mechanical parts were still in fine shape and performance was great. |
Posts: 10515 Location: Hustletown, TX |
sp949 wrote: After 38 years and over 42000 miles, the auto-lube in my PX 150E is still doing its duty without problems. The only "problems" with it are leaks of 2T oil, mostly from the plastic oil level sight glass, and failed gaskets under the air box. The sight glass develops cracks either on its nose, where you notice 2T oil on the left side of the floorboard, or around the threaded portion inside the frame. (Possible... that the sight glass threads in the oil tank are stripped, but I doubt it.)
Positive
Birdsnest wrote: This often happens bc the oil tank is not threaded high enough on the post coming from the gas tank. If the plastic oil tank is sitting to low, pressure from the frame cracks the sight glass. Easy fix. Pull the tanks and reseat the oil tank properly. Should fix the leak issue. (Possible... that the sight glass threads in the oil tank are stripped, but I doubt it.) The threaded piece on top along with a seal prevents oil leaks; it does not locate the tank. Choose another plastic tank and see if the site glass sits higher.
Positive
Make sure there's still the large thick gasket between the tank and the frame. If it's not there, it will lower the whole tank assembly slightly.
Positive
Birdsnest wrote: This often happens bc the oil tank is not threaded high enough on the post coming from the gas tank. If the plastic oil tank is sitting to low, pressure from the frame cracks the sight glass. Easy fix. Pull the tanks and reseat the oil tank properly. Should fix the leak issue. (Possible... that the sight glass threads in the oil tank are stripped, but I doubt it.) |
