Hey fellas,
I have an LT150 from 2003 with 11k miles on it (the last 1k were put on me with no trouble), and the engine has a severe issue of dying the moment I let it idle. I had this issue two weeks ago when it stalled out twice while idling on a 15 min drive, and I've since:
1) checked the vacuum tap (it provides fuel when vacuum is applied and cuts off fuel appropriately, so it seems fine.)
2) checked the fuel and vacuum lines; they are supple and uncracked.
3) replaced the spark plug; it was mildly blackened and sooty.
4) replaced the intake manifold; it was slightly cracked and has some grey rubber cement smeared on it, so I just got a new one.
5) cleaned the idle jet, main jet, and the carburetor diaphragm with carb cleaner.
6) cleaned the air filter.
When I did these steps last night, it started up perfectly and idled for 10~ minutes no problem while I adjusted the speed and mixture screws on the carb. However, I took it for a ride this morning, and after starting up/idling well , it once again stalled out just a couple miles into the ride.
It is now to the point where I NEED to give it PLENTY of throttle for the poor thing to start up at all, and it dies the moment I release the throttle and let it idle.
It seems I am back to square one with this issue except it is now somehow worse, my guess is something broke/shook loose on that first ride since putting everything back in place this morning, but I am reaching my wits end. Any wisdom would be sorely appreciated!
