Juan_ORhea wrote:
Replace your black fuel line with a transparent Tygon line and you'll be quite surprised by what goes on (and doesn't go on) in there. Fuel doesn't just gush into an empty line sealed off at one end, displacing the air, when the petcock is opened by vacuum. The needle valve in the carb has to open to let the fuel in, or you have to disconnect the line at the carb and turn the engine over a few times to let the fuel flow down the line, then reattach it.
Or, don't worry about it. If a little oral suction on the vacuum valve gets the fuel flowing out of the petcock, it's probably totally fine. If the carb is empty, the fuel will get to where it needs to be when it has a path to get there, though it might take a few cranks/kickstarts to get it going.
Fuel flowed one time when I put vacuum on it. Never could get it to flow again.
When I put the new fuel tap on, I'm going to fill the float bowl up with a syringe so there is no lag time to get fuel in the carb.
