The engine won't kick over when pulling on the right brake lever, but will when pulling on the left.
I'm worried that if the left lever suddenly quit, I'd really be stuck.
![]() Sat, 04 Mar 2023 14:12:57 +0000
MP3 - 500
Posts: 427 Location: Alabama, USA |
![]() MP3 - 500
I'm worried that if the left lever suddenly quit, I'd really be stuck. |
2015 MP3 500 ie Business
Posts: 958 Location: Belgium |
![]() BV350, Primavera 150, Yamaha Zuma 125
Posts: 3879 Location: Twin Cities, Minnesota |
Sat, 04 Mar 2023 18:24:58 +0000
sbaert wrote: And the question is . . . . ??? |
Sat, 04 Mar 2023 20:18:23 +0000
2016 Mp3 500ie Sport
Posts: 164 Location: California |
Some additional diagnostic info might help narrow down the issue.
Are there other symptoms with the brake leaver? Are any other systems affected by the brake being engaged or idled? Brake lights light up when the brake leaver is engaged? Do the brake calipers engage and the bike does not role / move when the brake is on? Any recent rough weather, muddy roads, or other recent source of corrosion? This is the parts diagram for the 2009 MP3 500ie. It indicates as "stop button" (parts 11) which appears to be the part that would engage with the brake. It might be worth removing the plastic covering the steering tiller to expose those connections for inspection for damage. https://www.parts-piaggio.com/piaggio-scooters/500-PIAGGIO-SCOOTER/MP3/2009/MP3-500/Electrical-system/Selectors--Switches--Buttons/1209/42/20072/2687 |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 42054 Location: Pleasant Hill, CA |
Sat, 04 Mar 2023 20:46:23 +0000
For goodness sake, just replace the RHS brake switch. Very cheap and easy to do. Keep a spare handy too, these switches get a lot of use and can fail.
![]() Sun, 05 Mar 2023 14:46:23 +0000
MP3 - 500
![]() MP3 - 500
Thanks for the various suggestions, and yes the lights do come on and the brakes do tighten up on the calipers.
I like the jimC suggestion of replacing the switch, however I must confess to suffering a complete fear of anything electrical. So could someone point me in the direction of where the switch is located. Thanks again for all your input. |
Sun, 05 Mar 2023 16:59:42 +0000
The brake lever operates the switch directly. Just uncover the rear of the brake lever, unclip the wires from the switch, unscrew the old switch and screw in a new one. Reconnect the wires. Button up, ride off.
![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni, 2008 Vespa S150
Posts: 8870 Location: Ashburn, Va. Home to the Internet |
Tue, 07 Mar 2023 00:49:28 +0000
As Jim says the switch is easy to replace, just be gentle with it cuz it is plastic.
![]() Thu, 09 Mar 2023 19:11:02 +0000
MP3 - 500
![]() MP3 - 500
Thanks guys for all your input, parts are on order with AF1 Racing.
