Vespa GTS Super
Vespa GTS Super
Hello,
I am preparing for the new season but I have an issue error P1536-12.
I noticied the delaer and they asked me for replaceing the fall senzor.
Does somebody can provide a list with rhe explanation of error code ?!
Scuter is running well,no problem.
Thank you in advance !
@jkj-fz6 avatar
@jkj-fz6 avatar
My guess is that the tip-over sensor (also called "roll-over", "fall", or "rocker" sensor) is causing the error. The first line of your display says "Tip over electric -- S.C. to Vbatt". I think this means that the tip-over sensor is stuck and there is a short circuit to the battery voltage.
It may be possible to fix it by tapping on the sensor. If not, it may have to be replaced. This may help:
Tip over switch
2019 GTS 300 HPE w Malossi
Are you sure it's P1536?
The manual says that P1761 is the code for that sensor error:
P1761 Electric tilting sensor SC to Vbatt Check wiring of tipover sensor and check with a diff erent sensor.
Vespa GTS Super
Vespa GTS Super
Hello,
Today I replaced the senzor eith a new one and the check engine is still on.
I hope after connecting the tester to dealer plant it will be over.
Thanks a lot !
[ Time: 0.0087s ][ Queries: 4 (0.0029s) ][ live ][ 343 ][ ThingOne ]
