@keltis99 avatar
GTS 300 super (US v.)
@keltis99 avatar
I replaced my water pump cover due to my oil being contaminated by the coolant on my 2014 GTS (20k km). I figured the water pump seals went and I spent a few hour with scooter west instructions carefully replacing the cover, gasket etc, flushing coolant, replacing oil etc. Now when the Vespa starts there is this squeaking noise from the water pump/exhaust area. The noise goes away when the Vespa gets warm. Any clues?
oil is normal now, coolant level is ok, scooter drives with no issues...
[/u]
Thanks for your tips
Just to clarify...you removed and rebuilt the pump itself?
@keltis99 avatar
@keltis99 avatar
No I bought a new WP cover (PI8798315) and replaced the old part as a whole. with labour and specialist tools made economic sense.
[/url]
⚠️ Last edited by keltis99 on UTC; edited 1 time
@greasy125 avatar
@greasy125 avatar
odd, to be sure. have you put any miles/time on it? it may just be tight seals/bushing that's seating in.
I'd try and put a few miles on it while monitoring the situation closely. if it doesn't go away rapidly it's time to pull it all back apart.
Buying a new WP cover is the best option.
[ Time: 0.0114s ][ Queries: 4 (0.0039s) ][ live ][ 343 ][ ThingOne ]
