Wed, 08 Mar 2023 02:46:18 +0000
parallelogramerist
parallelogramerist
Wed, 08 Mar 2023 02:46:18 +0000 quote
I'm looking to buy some PX/PK multi plug terminals (both male and female), the only caveat is that i'm wanting to buy about 10~30 of each...maybe even 50 of each? If i buy them individually from SIP...well, i don't want to talk about it because they cost about $1 each. Does anyone know of a supplier in the US who sells them in a small bulk quantity? I have absolutely no idea of any cross reference number for them. Or are they a proprietary terminal that Piaggio uses? They definitely are not a Molex connector.
Male terminal- https://www.sip-scootershop.com/en/product/cable-plug-multi-plug-wiring-harness_21836900
Female terminal- https://www.sip-scootershop.com/en/product/cable-eye-plug-1-0-2-5mm-cable-round-pin-bushing_21837000
Wed, 08 Mar 2023 03:06:46 +0000
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Lucky
Wed, 08 Mar 2023 03:06:46 +0000 quote
How exact a match are you looking for? these molex connectors are pretty darn close.
Wed, 08 Mar 2023 04:53:37 +0000
parallelogramerist
parallelogramerist
Wed, 08 Mar 2023 04:53:37 +0000 quote
Those Molex aren't even close...
larger Multi Plug in the left, smaller Molex on the right.
Wed, 08 Mar 2023 10:59:46 +0000
2007 Stella 225
2007 Stella 225
Wed, 08 Mar 2023 10:59:46 +0000 quote
Did you try Digikey or Newark?
Wed, 08 Mar 2023 12:47:05 +0000
1964 Allstate Cruisaire, 1966 Allstate Blue Badge Small Frame, 2022 Husqvarna Vitpilen 401
Wed, 08 Mar 2023 12:47:05 +0000 quote
A good place to start a search.
https://octopart.com/search?q=molex+pin&currency=USD&specs=0
Wed, 08 Mar 2023 13:37:39 +0000
parallelogramerist
parallelogramerist
Wed, 08 Mar 2023 13:37:39 +0000 quote
I didn't even attempt them yet. I'd be way over my head sifting through hundreds (thousands?) of different pin shaped terminal and would quickly get lost.
Wed, 08 Mar 2023 13:39:27 +0000
Wed, 08 Mar 2023 13:39:27 +0000 quote
Is there a part number or brand name on the connector housings?
Wed, 08 Mar 2023 13:43:22 +0000
1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Wed, 08 Mar 2023 13:43:22 +0000 quote
I have been using the ones found on PC PSUs. They're the same diameter and the tool that comes with them is really handy…
Wed, 08 Mar 2023 13:48:03 +0000
parallelogramerist
parallelogramerist
Wed, 08 Mar 2023 13:48:03 +0000 quote
Do you have any part numbers or a link to where you got them?
Wed, 08 Mar 2023 17:29:17 +0000
Wed, 08 Mar 2023 17:32:07 +0000
VNB VSC o9c VMA vbc vmb VSX
Wed, 08 Mar 2023 17:32:07 +0000 quote
Always with the good info!!!
SaFiS, you are a great resource to have contributing here.
Wed, 08 Mar 2023 18:00:45 +0000
Wed, 08 Mar 2023 18:00:45 +0000 quote
this feels like it belongs in a wiki for others to add on terminals for other applications....
Thu, 09 Mar 2023 04:12:54 +0000
parallelogramerist
parallelogramerist
Thu, 09 Mar 2023 04:12:54 +0000 quote
Thank you very much SaFiS! A second question...do you know what gauge wires can be crimped into those terminals? Ideally i'd get a few different sizes so that i couple crimp two different wires into the same terminal.
Fri, 10 Mar 2023 16:32:44 +0000
Fri, 10 Mar 2023 16:32:44 +0000 quote
I've managed to squeeze a 1.75mm² that I used on my T5's stator and the double grays on the loom's multiplug (I think they're 1.5mm²)...
Wed, 15 Mar 2023 05:37:44 +0000
parallelogramerist
parallelogramerist
Wed, 15 Mar 2023 05:37:44 +0000 quote
I ordered 100 males and 100 females. The modDIY website sure looks like it's a US based company, but it might be a while before all those connectors arrive from Tai Kok Tsui, HONG KONG. Hopefully it's shipping by air and not on a slow boat...
  DoubleGood Design
[ Time: 0.0276s ][ Queries: 6 (0.0054s) ][ Debug on ][ 276 ][ Thing Two ]
