@personality avatar
2009 GTS 250ie
@personality avatar
2009 GTS 250ie
I just bought a used GTS 250 and it needs shocks all around. I am plan on tackling the front first as I think that will make the biggest difference in handling.
So far I've come up with these options:
Bitubo $269.99 https://www.scooterwest.com/bitubo-front-shock-gt-gts-bi-gtfr.html
Malossi $204.95 https://www.scooterwest.com/malossi-paoli-rs24-front-shock-gt-gts-super-300-m4614137.html
Stock $106.95 https://www.scooterwest.com/front-shock-vespa-300-super-56452r.html
Am I missing any other options?
Is the Bitubo worth the extra money?
Any budget suggestions for the rears?
@greasy125 avatar
@greasy125 avatar
low mileage used stock take offs are the most budget friendly option available.
YSS makes okay aftermarket "sport" shocks
bitubo is probably the cheapest "performance" option available with SIP house brand being right there with them.
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
The adjustment capabilities on the front Bitubos are great and well worth it as far as I am concerned.
Keep in mind that the ride will then be "sportier" meaning less soft and cushioned.
2019 GTS 300 HPE SuperTech 72,000km
Also SIP. I have been using these for 2 years / 37,000km and like them.
https://www.sip-scootershop.com/en/product/shock-absorber-kit-sip-performance-front-rear_MV7801PMB
2007 Vespa 250 GTS
2007 Vespa 250 GTS
I recently installed a bitubo on the front of my 07 GTS 250 and it made such an improvement I ordered the same for the rear. A work in progress at the moment.
Tony @ 35k miles now
@preddybaer avatar
GTS300, CRF1000 & Moto 6.5
@preddybaer avatar
if you need street legal and the budget is somewhere in "mid", SIP & BGM should do excellent job
if budget no problem and you do not care much for MOT/HU, Bazooka!
@shebalba avatar
@shebalba avatar
I have the Malossi front and rears on my GTS250, same year as the OP. I installed them myself and have been happy with them.
I did the front a few years before tackling the rears similar to what you are proposing. The front shock installation is very well documented on this forum.
Malossi RS24 Front Shock Install on Vespa GTS Walk Thru
My only gripe, and its irrelevant, is the white spring color. Bit of a snoozer on my silver GTS. Some of the other shocks suggested are a bit sexier. Not that the rears are all that visible.
@personality avatar
2009 GTS 250ie
@personality avatar
2009 GTS 250ie
I ended up spending the extra bucks for the Bitubo. I installed it last night with minimal cursing and did a test ride today. It made a huge difference over the tired old original shock. The handling feels so much more confident and comfortable, I can now actually imagine riding this thing on the highway.
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
if you replace the rear shocks, replace the bushings as well. Clauss bushings is the recommended bushings https://www.claussstudios.com/store/p542/Vespa_GTS_GTV_250_300_Polyurethane_Upper_Rear_Shock_Bushings.html
2007 Vespa 250 GTS
2007 Vespa 250 GTS
I ordered from Clauss last Friday, they shipped today, the message? plan ahead
@mcruss avatar
'20 GTS300 Touring, '10 GTS300 Super (sold)
@mcruss avatar
"The adjustment capabilities on the front Bitubos are great and well worth it as far as I am concerned.
Keep in mind that the ride will then be "sportier" meaning less soft and cushioned."
Sorry, I don't understand this statement by gialo. The ride on my 2020 GTS Touring is anything but "soft and cushioned." I would be interested in an aftermarket shock if it would add some! My 2010 GTS 300 Super was the same. I added an aftermarket (don't recall the brand but not a Bitubo) and it did little to remedy the harshness.
Probably poorly adjusted.
And depending on what you're feeling should also replace rear shocks. the rear used to bottom out for me before I replaced them.
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
Aftermarket shocks often make the ride even harsher with but as a result, improve handling.
I find the OEM shocks adequate. Not necessarily soft and cushioned, but more so than my current aftermarket shock set up.
A Vespa has small wheels, it won't for example ever go over bumps like a big wheeled dual sport motorcycle. But then that dual sport bike won't turn on a dime like a Vespa can. Trade offs? Sure.
@rallygeek avatar
@rallygeek avatar
Do the new GTS 300 supertech models for 2023 use the same shocks as before. I am thinking of selling my current GTS and want to know if I should take off the bitubos of it to put on the new bike.
I can't see a shock for the 22 supertech on SIP.
I think front no but rear yes
@justjake avatar
'17 GTS 300
@justjake avatar
'17 GTS 300
I second this, but I couldn't get them to easily slide over my SIP rears. Tried grease, hammer, jousting, finally had to take a drill and bore it out a bit.
Same. I used a Dremel to enlarge the hole. The sip have bigger shaft than other shocks
[ Time: 0.0200s ][ Queries: 4 (0.0073s) ][ live ][ 334 ][ ThingOne ]
