Speedo is not working, ABS EFI and ABS lights stay on. What can cause it.
⚠️ Last edited by colosseo on UTC; edited 1 time
Posts: 8651 Location: Batmania aka Melbourne, Aus |
on an GTS with ABS the speedo is driven by the real wheel speed sensor via the ABS.
Did you have the rear tire changed recently? .... The speed ring / tone wheel on the rear could have become bent. Or the sensor for it might not have been installed correctly (apparently if the washers for the screw are missing that can cause problems as the spacing will be wrong?). Of course could also be any of the related wiring but less likely. |
colosseo wrote: Pic PS were there any washers when you took the screw out? AND as I asked, has the rear tire been replaced recently? |
CrackedEgg wrote: Anyone know if an ASR calibration would fix op's problem? asr wouldn't cause abs light or speedo issues. (although the opposite of abs light causing asr issue is possible)
Positive
colosseo wrote: Few more pictures Is the distance for the sensor to wheel in pic 2 correct? Thanks Have you checked the fuse for the ABS unit? |
Measured my abs sensor gab in 3 different spots rotating the wheel. 2 spots it fit and 1 spot it didn't. 0.787mm seemed liked the best guesstimate. I wonder what the spec is supposed to be?
CrackedEgg wrote: Measured my abs sensor gab in 3 different spots rotating the wheel. 2 spots it fit and 1 spot it didn't. 0.787mm seemed liked the best guesstimate. I wonder what the spec is supposed to be? Sensor distance - tone wheel > 0.8mm
Positive
I don't think it's the tone wheel or sensor anymore (now that you've recently shown enough pics etc.)
I'm thinking it's the ABS unit itself is not happy (as @greaasy said) or wiring somewhere between the ABS and the sensor. |
colosseo wrote: Is this the part? |
colosseo wrote: Ok, here are pics of the ABS unit (if mean anything) Thanks I'm not sure the difference between that 1C001631 which I see in the parts manual |
1C001630 seems no longer available from Piaggio. In none of the online stores you can find anything about it or it can not be ordered...
See also: 2015 GTS300 ABS pump 1631 / 1630 Compatibility status |
GermanGTSDriver wrote: As far as I know: A new ABS unit must be taught-in: PADS is required… * unusual ⚠️ Last edited by SteelBytes on UTC; edited 2 times
SteelBytes wrote: I think you're wrong*. reading the hpe manual for replacing the abs unit (very detailed instructions) it does not mention pads software. * unusual The installation and programming of the control unit must be carried out by a Piaggio workshop." https://www.scooter-center.com/en/control-unit-abs-piaggio-vespa-gts-125-zapma3100-vespa-gts-150-zapma3200-zapma3100-vespa-gts-300-zapm45200-zapm45202-zapma3300-vespa-gts-super-125-zapm45300-zapma3100-zapm45301-vespa-gts-super-300-zapm45200-zapm45202-zapma3300-gp1c001631 From this I concluded that programming with PADS would be necessary. What else could be meant here? *2016 is non-hpe |
GermanGTSDriver wrote: The installation and programming of the control unit must be carried out by a Piaggio workshop yet the manual doesn't ... |
