Fack! It looks like my carb is missing a piece, and looking for Dellorto parts appears to be a pain in the arse. Anyone encountered this problem and found a solution? Thinking about an adaptor of sorts made from a rad hose or something but maybe someone on here has a better solution?
Innovator
Posts: 12526 Location: Nashville 154 Days Since Last Explosion |
Innovator
Posts: 5353 Location: Oceanside, CA |
Marchald makes filters that should fit right on.
That said, I do want to add I had jetting/performance headaches running an air filter on my PHBH 30mm. I got it to work, but too lean for my liking. Running without the filter now where performance is better. |
Innovator
Innovator
Agreed. I could never get any of my PWK's to run to my satisfaction with a filter, even a really thin foam pod. That's from PWK 28's all the way up to 34. I didn't even bother with the 36 on my smallie.
They just refuse to breathe enough past about 6,500 RPM's. |
MJRally wrote: Marchald makes filters that should fit right on. That said, I do want to add I had jetting/performance headaches running an air filter on my PHBH 30mm. I got it to work, but too lean for my liking. Running without the filter now where performance is better. |
Innovator
Innovator
scrumpadelic wrote: Ooh... never thought of the Amazon. As I have the filter already I'm sure I'll be able to find the boot on there. Cheers. |
Posts: 5105 Location: Australa, Mate |
Mine has a bell-mouth that screws on the intake.
I use a coil/spring from an old Polini Foam filter, sew my own filters, and cable-tie them on
Posts: 2563 Location: Siam |
It's interesting how the original small frame air filter (V90, etc.) is more or less a metal box with a folded wire mesh inside. Maybe the reason it works is because it doesn't really do anything. I guess now and then a few dust particles stick to the oil soaked mesh.
Positive
Innovator
Innovator
nomadinsiam wrote: It's interesting how the original small frame air filter (V90, etc.) is more or less a metal box with a folded wire mesh inside. Maybe the reason it works is because it doesn't really do anything. I guess now and then a few dust particles stick to the oil soaked mesh. It filters rocks and loose screws out of the incoming air (a feature that can't be overrated) and keeps spitback contained so the cavity doesn't get all gummy. Any filtering past that is pure coincidence. |
SubEtherBASS wrote: Mine has a bell-mouth that screws on the intake. I use a coil/spring from an old Polini Foam filter, sew my own filters, and cable-tie them on |
chandlerman wrote: Hard Agree. It filters rocks and loose screws out of the incoming air (a feature that can't be overrated) and keeps spitback contained so the cavity doesn't get all gummy. Any filtering past that is pure coincidence. Shoul've asked here first lol. |
