Vespa Sprint 150 S, ex Vespa Elettrica L3 70 km/h
I have a 2022 Vespa Sprint 150 S which I am considering installing a Malossi Multivar variator. Does anyone have experience doing this, will it not only be quicker on accelleration, but also get higher top speed? It maxes on 113 kmh/70 mph today and I do not want it to go slower.
https://www.sip-scootershop.com/en/product/variator-malossi-multivar-2000_M5115639
Anyone?
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
Anyone?
Not sure but I think simply replacing Sprint or Primavera rollers with Malossi 12.5 gram rollers is the best bang for the buck, not life changing but a noticeable difference on take offs and getting up to speed with little worries about reliability and other unintended consequences
@mike_holland avatar
GTS300 Super 2023 Beige
I agree. Everyone compares aftermarket varios with the standard one, whereas the standard one can be tuned with lighter rollers and get much the same benefit. I have used Polini and Dr.Pulley variators, and currently have 12.5 gram rollers in the standard variators on my two GTS300s. I gave the Dr.Pulley one away, and the Polini sits in a drawer. Never tried the Malossi one.
@greasy125 avatar
@greasy125 avatar
just lighter rollers and/or some cvt tuning will probably get you the results you're looking for.
aftermarket variators are nice, especially when paired up with a cylinder kit.
@as0mesauce avatar
Sprint 150 S
@as0mesauce avatar
Sprint 150 S
I just installed my Malossi Variator on Monday. I don't see much of a top speed difference but it absolutely accelerates quicker and smoother.
what were the roller weights before the upgrade and after the upgrade?
@as0mesauce avatar
Sprint 150 S
@as0mesauce avatar
Sprint 150 S
Not sure what the stock weights are on a 2023 Vespa Sprint but the Malossi are 13.5g. Im very pleased with the outcome.
I got the kit from ScooterWest and followed Robot's video
https://www.scooterwest.com/malossi-variator-3-valve-piaggio-engines-vespa-946-primavera-sprint-m5115639.html
so with out the roller weight information or using the exact same weights you really can make a comparison on the variators performance differences. .
@as0mesauce avatar
Sprint 150 S
@as0mesauce avatar
Sprint 150 S
for the sprint 150 i-Get the stock weights are 14.5g
Primavera/Sprint 150 3v i-Get 20mm 15mm 14.5g
Standard Roller Weights
so by using lighter weight rollers that's what you feel in the improved acceleration.
[ Time: 0.0107s ][ Queries: 3 (0.0034s) ][ live ][ 343 ][ ThingOne ]
