px 125 disc
px 125 disc
I have a VMC 177 kit on my px with autolube and opinions seem to vary as to whether its a good idea/neccessary to add 1% oil to the fuel as well.
My thoughts are, as the oil is to lube the bottom end and the bottom end hasn't changed why is extra oil necessary? or am I missing something here?
@gickspeed avatar
@gickspeed avatar
running VMC 177 Stelvio, 57mm crank, 24.24 ER, Polini BOX, 23/65 gearbox in Malossi PX125 cases. .. . with autolube and NOT adding oil to the fuel. Cases matched to transfers in the cylinder 100%
⚠️ Last edited by GickSpeed on UTC; edited 1 time
px 125 disc
px 125 disc
GickSpeed wrote:
running VMC 177 Stelvio, 57mm crank, 24.24 ER, Polini BOX, 23/65 gearbox in Malossi PX125 cases. .. . with autolube and NOT adding oil to the fuel. Cases welded up and matched to transfers in the cylinder 100%
Thank you for that, for the record I added 1% for the 1st 100 miles but now its only autolube, Scoot is running great.
[ Time: 0.0089s ][ Queries: 3 (0.0028s) ][ live ][ 343 ][ ThingOne ]
