I just replaced my clutch cable like i always have except this time when i shift into any hear except nuetral the vike will move forward even with clutch held in. I have to hold the clutch and the rear brake so it wont take off on me. Anything helps thanks
In general, the clutch isn't fully opening up the plates. What that is you'll have to investigate. Either the new cable tension is off, the engagement arm of the clutch is in a different spot from before, clutch plates sticking, clutch cover or plunger issues?
Start with re-tensioning the cable and then the clutch cover arm engagement point.
