Vespa sprint V150
Posts: 44 Location: West mids |
Sat, 11 Mar 2023 21:13:13 +0000
Can someone help with this problem. I have come to remove my flywheel on my 150 sprint V VLB and when I've removed the nut there doesn't appear to be any internal thread for the puller. There is only a shallow ring cut out which looks similar the the groove that would house an internal circlip. I have considered drilling and tapping either side and make my own puller, but an I missing something simple?
![]() Sat, 11 Mar 2023 21:23:32 +0000
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Posts: 7532 Location: Nashville |
Lucky
![]() 76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
You're reading the situation correctly. There should be a circlip seated into that groove that the flywheel nut will use to self-extract.
Sadly for you, Piaggio moved away from that design pretty quickly for the simple reason that it didn't work very well. Also...what the heck happened to that poor flywheel? It should NOT look like that. |
Vespa sprint V150
Sat, 11 Mar 2023 21:36:15 +0000
Not sure what happened to it, but the previous owners did something that also broke a number of fins. I'm not gonna lose any sleep over it as I'm changing it to an electronic ignition anyway, Sip most likely. Just need to get my head around the wiring change. Any advice is welcomed.
![]() 1964 Allstate Cruisaire, 1966 Allstate Blue Badge Small Frame, 2022 Husqvarna Vitpilen 401
Posts: 752 Location: York, PA (the intellectual center of the universe) |
Sat, 11 Mar 2023 21:37:03 +0000
https://www.scootermercato.com/Scooter-Parts/Hardware/S-05981
https://www.scootermercato.com/Scooter-Parts/Hardware/S-01544 These two parts self extract the flywheel. And...damn, what happened with all the rivet looking things on your flywheel. Definitely not OEM. |
Vespa sprint V150
Sat, 11 Mar 2023 21:45:20 +0000
Awesome! Thanks…. That nut is on the shaft so I just need the cir-clip.
![]() Sat, 11 Mar 2023 21:57:41 +0000
Posts: 2098 Location: Santa Margarita,Ca. |
![]() Joined: Fri, 25 Jan 2008 06:06:15 +0000
If it doesn't readily come off I've had luck tensioning the circlip and coming back in the morning to find time and tension have done the trick.
![]() 1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 3506 Location: Veria, Greece |
![]() Weird 80's Vespas & Cool Vintage Lambrettas
Posts: 12891 Location: The state of insanity, SoCal |
Sat, 11 Mar 2023 22:36:30 +0000
SaFiS wrote: Smells like a bodge. A pic of the whole scoot?? |
![]() Fri, 17 Mar 2023 21:55:38 +0000
Posts: 4503 Location: That bushfire place |
![]() 2 matching N.Z. '69 VBC Super, 177cc Racer, VespaCross Bodge, Puch SRA150, Piaggio Zip 100! & others
greasy125 wrote: It's bajaj or some variant of such. See the other posts, bike looks okay-ish but the motor is a little SEA. |
![]() Fri, 17 Mar 2023 21:56:38 +0000
Put nut back on.
Add circlip where red is. Undo nut. Ohh, then curse as it doesn't work ![]() |
Vespa sprint V150
Sat, 18 Mar 2023 21:57:51 +0000
Didn't work and cursed a lot. Made a puller and removed it that way.
