2006 LX 50 4 stroke 2 valve
Hello, I found the location of the spark plug, and was able to get the tool down over the plug, but there is not enough room to turn it or even fit the screwdriver through the holes. Are there more steps I'm missing? thanks for your help
ZAP C 386B
spark plug location
spark plug location
@jkj-fz6 avatar
@jkj-fz6 avatar
Looks like you need a regular spark plug socket and a flexible ratchet.
What do you other LX 50 owners use?
thank you for your reply, I was thinking maybe some kind of ratched , maybe that's why the tools have never been opened
@jkj-fz6 avatar
@jkj-fz6 avatar
They are hard to reach. Watch your fingers!
Usually that tool is the only one worth keeping from the kit as it's perfect for getting the plug out.
You can probably pull it out a bit and it will still work.
@jkj-fz6 avatar
@jkj-fz6 avatar
I use a short piece of a car's fuel line slipped over the plug to make it easier to start to screw the plug in.
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
I just changed the plug in my LX 150. Not sure if it's the same as the LX 50. I ended up disconnecting the rear shock and jacking the body up a bit. That gave me enough room to work in the tight area. Major PITA.
[ Time: 0.0124s ][ Queries: 4 (0.0059s) ][ live ][ 343 ][ ThingOne ]
