Mon, 13 Mar 2023 08:45:04 +0000
Vespa sprint V150
Vespa sprint V150
Mon, 13 Mar 2023 08:45:04 +0000 quote
I'm restoring my 150 Sprint v and now the body is finished I'm working on the engine. Should I paint the engine with heat resistant silver paint to make it look pristine, or is that a bit too much?
Mon, 13 Mar 2023 09:42:58 +0000
Mon, 13 Mar 2023 09:42:58 +0000 quote
It's unnecessary as it will be covered in oil anyway which kind of preserves it an an odd way.
Mon, 13 Mar 2023 10:17:19 +0000
PX 200
PX 200
Mon, 13 Mar 2023 10:17:19 +0000 quote
I see folks do it, looks great.
But I'd advise against it because the aluminum oxidation gets hidden underneath and your crankcases end up becoming brittle.
Just worked on a crankcase which cracked as I took the bearing out. Surrounded by grey powdery aluminum.
I'd use the old method of WD40 and elbow grease to clean any aluminum.
Mon, 13 Mar 2023 11:14:53 +0000
Mon, 13 Mar 2023 11:14:53 +0000 quote
Will it get you home?
Mon, 13 Mar 2023 11:21:54 +0000
PX 200
PX 200
Mon, 13 Mar 2023 11:21:54 +0000 quote
Forgot to state, the cracked crankcases were painted silver…
Mon, 13 Mar 2023 13:05:29 +0000
bodgemaster
bodgemaster
Mon, 13 Mar 2023 13:05:29 +0000 quote
I love shiny painted stuff as much as the next guy … maybe more … but no, don't do it.
Mon, 13 Mar 2023 13:09:05 +0000
1987 Motovespa do Brasil PX200 elestart, 1979 P200E
Mon, 13 Mar 2023 13:09:05 +0000 quote
You can powder coat. but no need. Best solution would be to vapor blast. Looks great, helps keep grime from sticking. The only reason your cases get grimy is due to running garbage mineral oil and not cleaning your scoot. This is what nice vapor blasted cases look like.
Mon, 13 Mar 2023 13:10:57 +0000
Mon, 13 Mar 2023 13:10:57 +0000 quote
I find that paint doesn't hold up that well on an aluminum engine case. You could polish it out to almost a mirror like surface with enough time, but you would have to keep doing it. I'm happy with clean.
Tue, 14 Mar 2023 21:14:22 +0000
Tue, 14 Mar 2023 21:14:22 +0000 quote
Vapor blasting is the way to go. It comes out beautifully.
Tue, 14 Mar 2023 21:37:11 +0000
1958 Allstate 177VMC, 2005 70cc Yamaha Vino
Tue, 14 Mar 2023 21:37:11 +0000 quote
No, you should not paint it.
Tue, 14 Mar 2023 22:32:29 +0000
61 VBA
61 VBA
Tue, 14 Mar 2023 22:32:29 +0000 quote
Any bay area places you'd recommend for this?
Tue, 14 Mar 2023 22:41:37 +0000
Tue, 14 Mar 2023 22:41:37 +0000 quote
There's a place in Santa Clara called Spray Technology. I haven't used them.
https://www.yelp.com/biz/spray-technology-santa-clara
I used a place called Scooters Originali in Portland. I just mailed the parts to them. They came out really nice!
https://scootersoriginali.com/pages/vapor-blasting
This was from Scooters Originali.
Tue, 14 Mar 2023 23:17:47 +0000
61 VBA
61 VBA
Tue, 14 Mar 2023 23:17:47 +0000 quote
Wow, looks amazing!
Thanks for the rec's!
Tue, 14 Mar 2023 23:29:19 +0000
The Dude
The Dude
Tue, 14 Mar 2023 23:29:19 +0000 quote
I also subscribe to the dont paint it camp... although I understand, because I love the look of a colored or black engine case. Others have made very good points. Here is my half penny thoughts
Silver paint will always look like silver paint, especially on a Vespa engine; and it will not last long. If you want the og aluminum look there are a few options:
1. Basic scrub down. clean it really well by hand & pressure washer & inox wire brushes. works great, and you'd be surprised at the potential for very clean outcome! I've had many engines which I though were hammered, and after a good clean they looked great; no expensive finishing required.
2. Vapor blast. Basicly a fancy name for "wet-mediablasting". Its pressurized water mixed with media. Much less harsh than dry blasting, and better long lasting finish. All done by hand, and is usually charged an hourly rate.
3. Tumbled media finish. Parts get 'tumbled' in a large media finisher. Slow process, but its basicly labor free. Toss in dirty parts, hours later pull out clean shiny parts! Tumbling supposedly helps to 'seal' up the pores of aluminum, and gives a dull-shine appearance. I think there are only 2 (scooterist) guys in USA that do this. Cost probably about the same as Vaporblasting.
4. Polished alum. Break out your sandpaper and prepare to get buff! sand down all the pores until its smooth, then buff it out to a shiny finish! Obviously more complicated than that, but this is ageat look! Also.... be prepared to ALWAY be polishing your engine. Oh and did I mention you'll always be polishing your engine. Looks rad tho!!
5. Powdercoat. This is about the only way to effectivley coat your engine case with a long lasting finish. Its not necessary at all, but the sky's the limit on color and finish choices!
** followup question, did you say your cases were already welded? How so... welding is not uncommon on these cases, I'm just curious
Whatever you choose to do, good luck!
  DoubleGood Design
[ Time: 0.0294s ][ Queries: 6 (0.0044s) ][ Debug on ][ 276 ][ Thing Two ]
