So a PK75, motovespa, SHBC L 20mm carb has had engine cases split for a good old refurb of seals, gaskets, bearings. All put back together, carb refurbed and reassembled and the fuel tap on tank was shot, leaking. New fuel tap put on as it was leaking and stiff, but a fast flow tap. Fuel line put back on, scooter started 2nd kick, then dialled in the carb, all good. Kicked it over again, all good, then again and again.
The fuel tap has a reserve on it. As soon as i put the tap on to reserve scooter stops running then refuses to kick over at all. I mean WTF is this all about. So leave it for a week, fuel turned off as ran out of time. Kicked over, it started, blah blah. Turns the fuel tap to off or to reserve or normal position, same thing, no starting. So left another week as felt like i was going to have an angry moment.
Decided to reinvestigate the carb. Couple of things, washer missing on the fuel intake cover and the choke valve brass locking nut at top of carb damaged. OK, ive got a brand new genuine delly SHBC 20L that i had spare to hand, jetted it 2 pts up for exhaust, put it on, dialled in, all good, tickover good, no smoking. Soon as i put the fuel tap to reserve, the bastard thing did exactly the same, conked out and refuses to start. I cant try push starting it as ive got a damaged back.
Now what the frig is going on here? Is there an issue with a fast flow tap on a small frame? Is there too much fuel pressure, gravity say for the carb? Is this causing issue? Is my fuel line too short, its 12 inches long and new piaggio fuel line. Its absolutely doing my head in, any clues people? And yes, ive removed fuel cap to see if it would run and nope, it doesn't.
Any ideas as to what is going on folks? Thank you.
