Motovespa 150s lambretta li150
Hi all
I have fitted a px engine to my motovespa 150s and wish to keep the electric start as my knees are goosed. I tend to leave the battery on a trickle charger as the regulator I have is the wrong one but would like to fit the correct one that will provide the correct dc output to charge the battery. The one I have overcharges and cooks the battery. Appreciate Amy help with the correct one to order.
Thanks Matt
@safis avatar
@safis avatar
What's the stator and regulator you have??
It's the latest stator the restricted one I think its a 2016 engine not sure of the regulator as away from home at the moment.
Matt
@safis avatar
@safis avatar
If it's the restricted stator, it has the "usual" blue-black output. The correct regulator for this engine is the following.
G - AC in from stator (blue), G - AC out (regulated), B(+) to battery (+), C - 12V DC in from battery when main switch in ON position, last one is ground to chassis. Try to find a Ducati one, everything else is crap...
Hi thanks
I am not using any ignition switch will this matter? Or shall I just fit a simple switch ? Thanks for your help.
Matt
[ Time: 0.0137s ][ Queries: 4 (0.0056s) ][ live ][ 335 ][ ThingOne ]
