Tue, 14 Mar 2023 21:01:37 +0000
Tue, 14 Mar 2023 21:01:37 +0000 quote
Back with more BGM 177 tech-
This time to 1979 p125x cases.
There is plenty of gasket surface to bolt the BGM 177 cylinder kit on & go! This means ZERO reason to bolt on a DR 177 (1980's tech).
Matching case to the cylinder if you go this direction-leaving no power on the table.
You can match the case in the clutch side; plenty of material to work with on the case.
Matching to the Flyside will be problematic as you are going to break through. Find a good TIG welder or send to a competent mechanic or myself to weld up the area.
Lastly, don't use JB Weld; do it right the first time.
BGM 177 gasket applied to p125x case.
I have outlined the transfers of the cylinder onto the case.
A magnitude of material on the Clutchside, you will not break through.
Flyside case. Red arrow points to the area that needs material added to the case.
Area filled up with material.
Wed, 15 Mar 2023 01:24:26 +0000
Vespa
Vespa
Wed, 15 Mar 2023 01:24:26 +0000 quote
Wow looks great can you post a follow up after the transfers have been matched. Any work to the rotary?
Wed, 15 Mar 2023 10:35:51 +0000
Wed, 15 Mar 2023 10:35:51 +0000 quote
Just information. The information may help someone decide which direction to go with p125x cases.
Wed, 15 Mar 2023 14:10:46 +0000
Wed, 15 Mar 2023 14:10:46 +0000 quote
just a quick note - the caption you will not break through should read on the fly side. the picture makes it clear but...
  DoubleGood Design
[ Time: 0.0235s ][ Queries: 6 (0.0025s) ][ Debug on ][ 276 ][ Thing Two ]
