@oldschooot avatar
@oldschooot avatar
Simple servicing the Liberty is not a challenge most days.
This morning I set a personal record for screwing up a simple oil & filter change. (serv manual says 10,000Km between oil & filter changes. (6.2K miles) I do yearly, or every 2000 miles, which ever comes first)
Today:
Oil spilled 3 X~!
Forgetting the screen, X 1.
Losing the 0-ring, X 1.
and none involved the refilling process into the micro-fill hole - which is usually the most entertaining part!
Not a lot of room under there...
Channel locks works the filter.
A shorty 24mm socket does the drain plug.
Looking forward to a dawn ride tomorrow. 47°F, 90% rain and 20mph headwinds. But it's the best chance for decent temps I've had in 2 weeks.
Should be exciting with tree debris from the storm.
300 GTS Touring
300 GTS Touring
Oof. I managed to break the end off my dipstick when checking the oil level. Luckily it was after the first wipe so I was always going to pull it out again to check. Could have had that inch long piece getting up to no good in there and not knowing. Phew.
[ Time: 0.0160s ][ Queries: 4 (0.0042s) ][ live ][ 343 ][ ThingOne ]
