hello ,when i turn my handlebar to the right i ear and feel cables streching ,so i decide to lift the front wheel of the ground (by pushing down the rear rack).when i turn the handlebar to right they go back to the left like they are spring loaded .does your vespa do the same? I have a 2022 gts hpe with 450 miles only. This morning i decided to remove the headlight assembly and the culprit to have a better view ,i didn't find anything obvious .Please let me know. Thank you
Posts: 8029 Location: Batmania aka Melbourne, Aus |
tinddu wrote: i decide to lift the front wheel of the ground (by pushing down the rear rack).when i turn the handlebar to right they go back to the left like they are spring loaded |
No, that's not normal. It seems like some cables are pinched and not able to shift around properly. If you are still under warranty, go back to the dealer.
wentwest wrote: No, that's not normal. It seems like some cables are pinched and not able to shift around properly. If you are still under warranty, go back to the dealer. |
SteelBytes wrote: moving to the left when the wheel is off the ground is normal |
The suspension, brake calliper and brake disc are all on the left hand side - so the weight should pull the left hand side down when the wheel is off the ground.
2015 Sprint 150, 2018 GTS 300
Posts: 894 Location: SoCal |
tinddu wrote: Your vespa does the same like is spring loaded? pretty sure all of them do this But the headset bearings should feel smooth with zero play. |
No play in bearing. When my handlebar are on the right position handlebar go quickly to the right with the wheel of the ground My dealer is 2hours away it's why I was asking in the forum if your gts does the same, I don't feel driving 4 hours round trip for nothing.
wentwest wrote: If "they all do that" then I'd go to the dealership and test the theory on another one. |
tinddu wrote: hello ,when i turn my handlebar to the right i ear and feel cables streching ,so i decide to lift the front wheel of the ground (by pushing down the rear rack).when i turn the handlebar to right they go back to the left like they are spring loaded .does your vespa do the same? I have a 2022 gts hpe with 450 miles only. This morning i decided to remove the headlight assembly and the culprit to have a better view ,i didn't find anything obvious .Please let me know. Thank you |
Vespian wrote: I happened to have my 2022 GTS on a jack today and my front wheel does the same thing. I can turn it to the right with barely any resistance, and I can hear a tiny bit of cable squeaking, but when I let it go, it turns fully back to the left on it's own. As long as yours freely turns lock to lock, it's fine and normal. |
