Sat, 18 Mar 2023 18:34:51 +0000
PX 125
PX 125
Sat, 18 Mar 2023 18:34:51 +0000 quote
Got a 2016 PX 125
Starts and runs but after 5 miles bogs down cuts out, brand new spark plug is black and sooty had 4 new plugs so far.
Has a zip 2 road exhaust all else standard.
Carb gas been cleaned an new float seemed to help but still doing it
Ideas anyone????
Tue, 21 Mar 2023 20:48:58 +0000
PX Vespa 125
PX Vespa 125
Tue, 21 Mar 2023 20:48:58 +0000 quote
My guess is the jets main one try a 102 ! And make sure you are using the resistor type plugs l have a 2015 PX 125 but stay standard set up just the cat part removed with a granini manifold down pipe to the original box exhaust and just opened up the air filter 5 8 mills over the jets with a 98 main jet and it stopped All that bogging !! On the get go ! Good luck with everything just keep it simple and standard best foot forward soulboy74 🏴󠁧󠁢󠁥󠁮󠁧󠁿
Tue, 21 Mar 2023 22:25:49 +0000
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
Tue, 21 Mar 2023 22:25:49 +0000 quote
It can be CDI or stator problem also.
Thu, 23 Mar 2023 19:29:51 +0000
PX Vespa 125
PX Vespa 125
Thu, 23 Mar 2023 19:29:51 +0000 quote
Just wondering how you are getting on with the vespa !! Normal black plugs ! Is a sign of the engine running Rich !! You need to be more careful with our 2011+ vespa technical difference you should be alright with only a sip 2 upgrade but Hay mate you do need to sort out the right jets!! 100 main jet should do the job ! But you must check that all the other one's in the stake are correct and standard set !! If All alse fails go standard set up !! Most reliable way best foot forward soulboy74 🏴󠁧󠁢󠁥󠁮󠁧󠁿👍
Mon, 27 Mar 2023 10:26:33 +0000
PX 125
PX 125
Mon, 27 Mar 2023 10:26:33 +0000 quote
I am thinking it's stator plate
Mon, 27 Mar 2023 11:07:15 +0000
73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 90 V5N 50, 01 ET2, 2015 HD Road Glide Special
Mon, 27 Mar 2023 11:07:15 +0000 quote
What main jet is in the carb? Pull it and read the three different numbers stamped on it.
  DoubleGood Design
[ Time: 0.0257s ][ Queries: 4 (0.0044s) ][ Debug on ][ 276 ][ Thing Two ]
