So I finished the rebuild of the P200 and it runs great, Starts up great. Shifting was rough at first but I adjusted the selector cables and can row through the gears nicely when it is moving. However, When I come to stop and put it in 1st gear with the clutch lever fully pulled, it's not engaging and releasing properly and the bike is popping into first with the clutch engaged and upon release lurching forward and then the engine dies. In other words I can't slowly release the clutch lever and move into1st smoothly, it's just popping straight into gear and popping the front wheel, so I have to be very careful not to give it too much gas or it will pop a wheelie ;o)
The engine was totally tuned up in the 90s by Moto Strada in MD, 2k original miles, and it runs great but the bike has sat since like 2000. I put in 80W gear oil as recommended until it was flowing out of the top fill hole. Do I need to lube the clutch or do I need to tear the engine down. Trying to avoid that as I just installed it, but these things happen. Anyone have any advice on steps I could take to fix this prior to pulling the engine? Thanks in advance. PS. When I had the clutch tension higher I had more spring in the clutch but then I could not shift it through the gears.
