Vespa Bachetta 125
Vespa Bachetta 125
Hi all, I'm restoring a Vespa bachetta V13 engine and looking for help regarding the proper degree setting for timing ? Thanks
@mjrally avatar
@mjrally avatar
Dont know that model but that doesnt mean much. In general though, most stock Vespas are around 24* BTDC. Try that for starters.
@gickspeed avatar
@gickspeed avatar
33 degrees before TDC.
Enjoy the power of the 1-port engine. probably will not be any tarmac left on the road once you get it setup and running.
Vespa Bachetta 125
Vespa Bachetta 125
Thanks guys, much appreciated
Vespa Bachetta 125
Vespa Bachetta 125
Hi guys, can you recommend a 6volt electronic ignition for farro basso v13 ?
@gickspeed avatar
@gickspeed avatar
you need to measure the inner diameter of your original fan, as you will bolt that onto the ignition hub.
this one is 98mm
https://www.sip-scootershop.com/en/product/ignition-sip-performance-by-vape-road_510026RA?q=v15%20ignition
[ Time: 0.0109s ][ Queries: 3 (0.0051s) ][ live ][ 343 ][ ThingOne ]
