honda elite 250, honda elite 150, yamaha vino 2k, vino 4k, etc.
Posts: 10 Location: indiana,usa |
hi all new old 2008 mp3 400 with almost zero miles. Maybe someone could list a few trouble areas to look for when getting an old but unused bike back on the road. I have changed the oil and am about to change coolant but not sure I can look at other areas without setting off an alarm or disabling bike as the master key I discovered is lost and will be needed to make new keys or to turn off alarms. This bike is disturbingly complicated for me as I am used to really simple 2 stroke 50s with no real gizmos involved. Thanks if you have any things to be considered before I ruin the bike.
nearest service facility is 40 miles away
Steering head bearings. They are the Achilles heel of the MP3. Get the special tool and grease them with every oil change or ideally every 5K km/3K mi
Also change all fluids and filters. Use G12 spec coolant (VW/Audi pink stuff) And be careful bleeding the coolant system. Loosen the bleeder valve during the bleeding process, otherwise you will have a airpocket that will overhead/destroy the head of the motor. |
thank you for fast reply. I will look for that grease gun online. and the air pocket warning will be kept in mind. it is fun to ride but I am going to get spare keys made before I lose the original. the code card was found just now and I am hoping the 'master key' can be replaced. I put it on the center stand on a soggy dirt patch and it fell over surprisingly easy to lift back up. no damage.
2009 Genuine Stella 2T (Sold). Helix Hunting.
Posts: 1287 Location: Texas |
BuddyBoy wrote: thank you for fast reply. I will look for that grease gun online. and the air pocket warning will be kept in mind. it is fun to ride but I am going to get spare keys made before I lose the original. the code card was found just now and I am hoping the 'master key' can be replaced. I put it on the center stand on a soggy dirt patch and it fell over surprisingly easy to lift back up. no damage. |
Any strange electrical faults you need to check the fuses. Strange system with a master fuse feeding multiple sub fuses which are inclined to suffer from dirt and corrosion.
yes not a great start but at least I got it off the truck without it killing me!
I highly recommend changing the brake fluid in both the brakes and tilt lock system.
I had found the brake fluid in the tilt lock had turned to gel in the spring (?) locks. Check your tilt lock pressure switch for leakage too. I discovered the small water pump nippel is frail too. I broke mine very easily. I have an aluminum water pump cover coming from Europe Enjoy the machine, they are weird and wonderful |
Posts: 4885 Location: El Pueblo de Nuestra Señora Reina de los Ángeles sobre el Río Porciúncula |
25BIKEZ wrote: Lock the front suspension when you stop/park it. Shouldn't be able to fall over then. The only problem was the (I think it's a solenoid) valve developed a leak causing the scooter to slowly lean over when parked. It was a simple, inexpensive fix. |
sbaert wrote: Steering head bearings. They are the Achilles heel of the MP3. Get the special tool and grease them with every oil change or ideally every 5K km/3K mi Also change all fluids and filters. Use G12 spec coolant (VW/Audi pink stuff) And be careful bleeding the coolant system. Loosen the bleeder valve during the bleeding process, otherwise you will have a airpocket that will overhead/destroy the head of the motor. |
just a quick question. anyone know where the front suspension grease fittings can be bought for a decent price? scooterwest wants 24 dollars plus shipping each. seems a little steep.
https://www.scooterwest.com/tool-for-lubricating-mp3-fork-bearings-020943y-ia.html I know its an imported hard to find kind of thing and all. seems a bit much Im here in the united states. thanks. nearest service place is 40 miles. flying carl 'I discovered the small water pump nippel is frail too. I broke mine very easily. I have an aluminum water pump cover coming from Europe ' is this the nipple used to bleed the water system? thanks. |
Posts: 23204 Location: Harriman, Tennessee, Tn |
BuddyBoy wrote: just a quick question. anyone know where the front suspension grease fittings can be bought for a decent price? scooterwest wants 24 dollars plus shipping each. seems a little steep. https://www.scooterwest.com/tool-for-lubricating-mp3-fork-bearings-020943y-ia.html I know its an imported hard to find kind of thing and all. seems a bit much Im here in the united states. thanks. nearest service place is 40 miles. flying carl 'I discovered the small water pump nippel is frail too. I broke mine very easily. I have an aluminum water pump cover coming from Europe ' is this the nipple used to bleed the water system? thanks. |
![]() thats one fitting per side, right? I dont need to loosen the bottom bolt and grease that area? I just want to get the right number of grease fittings when I order. thank you. The bike is shoved back into a corner of the garage and it would be difficult to go check without dragging it out. I need to clear out my garage obviously. |
BuddyBoy wrote: ![]() thats one fitting per side, right? I dont need to loosen the bottom bolt and grease that area? I just want to get the right number of grease fittings when I order. thank you. The bike is shoved back into a corner of the garage and it would be difficult to go check without dragging it out. I need to clear out my garage obviously.
Positive
BuddyBoy wrote: anyone know if a 'master key' can be made with only the code card and the secondary key? I assume this happens a lot with people losing this master key because it is not used except for dealer maintenance. You can't create a new masterkey (this has the task to be able to teach further keys), but a good locksmith can make a copy/clone of the blue key (without having the masterkey). Creating a new master key is only possible with a new/reset ECU (the first learned key is always the respective master key). You can find suitable Piaggio key blanks in the large online stores. ⚠️ Last edited by GermanGTSDriver on UTC; edited 1 time
thank you all who have been following. dariusz I am up to date on how the grease thing works on the front 4 fittings. next question is Can i just buy grease fittings and leave them in for all 4 of the bolts/fittings? seems like a waste of time to keep taking them out and replacing them after each grease job, which is an annual thing at least. are the grease fittings subject to failure? I think i will try just leaving them in and keep an eye on leakage/seepage of grease if any appears. It can't be too difficult to look for grease after every couple rides. Thanks again for input and manual referral.
german gts I will check with a locksmith on a key backup. I am sure they can handle a copy. just wish the car dealer that sold this to me had let me know but I probably would have bought it anyway. this thing is a lot quicker than the 250 i test rode couple years ago. flyingcarl-I found the bleed valve for water pump. thank you and will report if bleed and water flush is success. |
BuddyBoy wrote: Can i just buy grease fittings and leave them in for all 4 of the bolts/fittings? seems like a waste of time to keep taking them out and replacing them after each grease job, which is an annual thing at least. are the grease fittings subject to failure? I think i will try just leaving them in and keep an eye on leakage/seepage of grease if any appears. It can't be too difficult to look for grease after every couple rides. Thanks again for input and manual referral. Now the other side of the coin. There are several people who say they have left them on and have had no problems. In my case I would not risk a failure of any of these screws. |
Quote: From what I read, is not recommended leave the screws with grease fittings on, since the hollow ones are much weaker than the normal ones (which makes sense) Does it have something to do with how much grease actually gets into the joint and efficiency of spreading it around? The bolts expensive but I'll gladly buy it if the value add is indeed worth it. Thanks |
pinheadh78 wrote: If such is the case, do we actually need the grease bolts? Could we just remove normal bolt, stick a tube in the hole to fill it with grease, and then replace the original bolt? |
I would not have recommended to buy it, with age there will be lots of problems and these types of scooters are expensive, as you will find few mechanics that work on them. I had one (400ie, 2009) and the mechanic used to work on it, informed me that he does not anymore and recommended to take to other, as it takes too much time to take it apart and put it back on. Then it started dying by itself: it used to stop while I'm riding, and one mechanic told me that is with the electrical issues and you need to test it from time to time (costly to do), and although I was sad to see it get written off (maybe lucky with that, I had an accident), but it was good that I changed it. I would recommend to stay at least 6 or 7 years old scooters, not older. But good luck with it. They are good machine (I don't want anyone thinking I am bad mouthing them).
I bought a 2008 MP3 500 as a project, and over a period of months did much as you are doing, learning how to do all the maintenance myself. There are many systems that are not similar to other scooters. I found that the most useful thing to do was to strip off all the plastic body covers and prepare to simply leave them off until you are satisfied you have done everything you plan.
There are several specialists who can help you with what must be done to get a master key. I would call either AF1Racing in Austin, TX or ScooterWest (Vespa Motorsport) in San Diego, CA. Make sure you tell them you have the card. The FSM is available free online from various sources. Start Googling. The same machines are also called Gilera Fuoco and either manual will be very helpful. |
went west, I will take off the panels as I go and just leave them off til I get acquainted with the innards on this bike. It is not critical that I ride this before I know that it is ready. Will check on the master key soon. thanks. Always wanted one of these and now I have a little disposable money for something new.
abcdef, I appreciate your caution in this but if it doesn't work out it is ok. I'd rather try something new than get stuck in the rut I've been in for a while. This forum has some excellent members who are very helpful. Besides, this thing is a blast to ride. The roads around here really are from hell so the extra traction is nice. |
I forgot to mention that there is a hidden fuse where the plastic connector links the low tension wiring to the starter solenoid.
