ferriswolf wrote:
Have you popped the headset cover off and ensured the ribbon cables are seated and clean ? I assume an lml will be similar to px. If the float wasn't working or for some reason it wasn't electrically connected right from tank you would get permanent amber low warning light . You're not getting that far so just check the headset end. I'm not even sure you can fix headset end other than check electrics attached. I seem to think you have to buy a new Speedo unit. Somebody might correct me but sure this is the case as it's sealed unit. Some of the earlier lmls had really shitty wiring . Push your Speedo cable up from front wheel when you remove the four headset cover screws to give you slack and more movement then you can disconnect the Speedo drive from Speedo and check the electrics seated ok. It's a ribbon type cable so maybe squirt with switch cleaner in case it's crapped up. I assume your Speedo light is working etc?
I'll certainly try all that when I get chance before I start to buy new bits all other lights on speedo work ie when lights are on and indicators are blinking etc...... The fuel gauge itself is stuck at about quarter of a tank so not sure the Amber light would be on as not showing that low 🤔🤔.
Really appreciate all ya help pal cheers 👍
