@scooter_curmudgeon avatar
GT200/GTS300/Primavera 150
So I just rode home from my local shop on my "new" (2007) GTS250. When I went to reset the clock, I could change the hours, but I'm not able to toggle to the minutes adjust mode, and the minutes reads :99, and does not change.
I understand from reading previous posts that the GTS does not have a separate battery for the clock, so it does not seem as if this is an indication of a dying clock battery, as I initially theorized.
I am now unable to exit the clock set mode, no matter what button or combination of buttons I press.
Has anyone here seen this, or have any ideas about how I might restore the clock function and return to "normality"?
Thanks,
Bob
⚠️ Last edited by Scooter Curmudgeon on UTC; edited 1 time
@25bikez avatar
2007 Kymco People S 250. Helix Hunting.
@25bikez avatar
Does the instrument panel/clock have a fuse?
Barring that, maybe disconnect the positive battery cable for a 10 count and reconnect it to see if that reboots the system.
Good luck.
Fuses are all good, I wasn't clear on which is dedicated to the panel/clock.
Escalated to "unplug it and plug it back in", which worked. I was then able to reset the clock and exit the adjust mode.
Thanks for the suggestion, this is why I love this place.
Bob
[ Time: 0.0103s ][ Queries: 4 (0.0030s) ][ live ][ 343 ][ ThingOne ]
