Trying to remember where I left off…
So everything came apart, the usual push/pull bearings and shafts. Nothing reusable.
So business as usual.
Gearbox is dead. All loose and way past shimming tolerances. A new PK gear set will be used.
Except the driveshaft small bearing… realised the material is super thin…! And with aluminium oxidation, a lot of the surface became powder (don't spray your cases, it's all masking the powder).
The cases cracked as I pulled the bearing out…
Ended up welding the crack. Which started a whole new saga of getting the bearing to fit
Cases apart ready for cleaning
Bearings out… 90% shot… loose and burnt
Can't really see it, but cracked on the inside
