Family member owns a 2008 LX50. Probably has less than 500 miles on it. It's been sitting for years. Last time I tried to get it going (2018?), it took forever to fire up, then stalled right away. Spent hours cleaning the jets and carb. Starting got a little easier, but as soon as you gave it some throttle it died. Was never able to ride it. I suspect we cooked the electric starter too.
So…..where to begin. I hate to see it sitting there.
I'm thinking of buying a new carb instead of messing with the original one. Can you recommend a new carb with part #?
Also, what's the part # for the starter? And how can I diagnose that?
Does the battery need to be good to use the kick start? Or will it start without a good battery up using the kickstart.
I'm fairly handy with cars and small engines (general maintenance) but never worked on a vespa.
It seems these things aren't worth much at this age, so don't want to spend a fortune,
Where should I begin and in what order?
