@chandlerman avatar
Innovator
33 Days Since Last Explosion
Innovator
@chandlerman avatar
First off, say that seven times fast.
Then, I'll tell you what I did to sort out some persistent fuel flow issues I've been having with the GL. I assumed it was either a kinked fuel line or fuel level issues or something else physically preventing the flow.
After I replaced the fuel line with a toyo line, which is both non-kinking AND transparent, I realized that the issue was NOT that the fuel line was kinking, but that it was generating an arch which was creating an air bubble in the line in the arch where the line went up and back down into the carb.
I used a 90 degree brass nipple I had on the shelf, cut it down to the length of the original nipple, then JBWelded it in place. I expect it will be ready to test tomorrow, but am cautiously optimistic that the GL's fuel flow issues will now be resolved.
The problem
The problem
Solution (I hope)
Solution (I hope)
@oopsclunkthud avatar
1:3
or tap into the side
Edit: OK, it pisses me off that Polini didn't think of this!
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I thought about that, too, but decided to start with this approach because it's easier. If it doesn't solve it, that'll be next.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I'm sure they thought of it, they just didn't see the value because side draft large frames are a tiny market compared to...well...every other use case.
@108 avatar
V range 50s
@108 avatar
V range 50s
Yeah should work! Did that on mine, drilled and epoxy, solved fuel flow issues.
No need for a pump or anything like that.
Also I added a 70deg banjo and drill through the frame.
I think the total length of the hose and banjo is something like 9inches… pretty direct to carb setup.
Drilled through the side to make it a 4mm hole to the float needle. Banjo hole was 6mm
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Mines the same way, I haven't had the cajones yet to pull out press fit and put in a 90. I just don't have a reserve, which for most of my local riding is fine.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I'll be happy to ditch the pump. Just one more piece of complexity I can now avoid. I run my fuel line through the bellows hole, which is close to what you've done. I avoid the post-painting drilling that way.
And Patrick, I realized there's also an engineering reason that Polini, et. al. don't supply a horizonal nipple--the 90-degree angle means that the fuel nipple is now a lever that can be twisted and break it loose, and they probably wanted to avoid the risk (liability) of selling something with that failure mode.
@garncarz avatar
@garncarz avatar
Add an air bleed at the carb?
https://www.steinertractor.com/IHS5662-Fuel-Filter-Bleeder-Valve?mkwid=|pcrid||pkw||pmt||slid||pdv|c|product|IHS5662|pgrid||cpgnid|17561055818|ptaid||adtext||&gclid=CjwKCAjw5pShBhB_EiwAvmnNVyaCcgE5cSLlQLWQ0O-xw-LSvCqdC5Hn7IFP4kSN8RvvtwkS7E5jchoC93AQAvD_BwE
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
My fix worked great. The goal was to improve reliability and, ideally reduce complexity, so adding bits would be a Last Choice.
[ Time: 0.0101s ][ Queries: 4 (0.0035s) ][ live ][ 339 ][ ThingOne ]
