Hello!
What to do if the opening on a newly installed headset is too wide to be able to tighten and fit it well onto the steering column?
Hello!
What to do if the opening on a newly installed headset is too wide to be able to tighten and fit it well onto the steering column? |
Posts: 2563 Location: Siam |
New reproduction. I think there are no new original headsets available any more.
But anyways it ascended to the Vespa heaven at 40Nm.
Posts: 15121 Location: The state of insanity, SoCal |
wow. what a bummer. I was literally just about to warn you about over tightening it. I have one that's broken just the same.
it's NOS, so I just can't bring myself to throw it out. |
That's a total bummer. You might try looking for a used original one. New stuff just isn't what it's cracked up to be (pardon the tasteless pun).
2007 Stella 225
Posts: 3547 Location: Rochester, Minnesota |
Would a shim material have worked wrapped around post and say epoxied to headset side. Then maybe a gentle squeeze and let it setup?
Johnny Two Tone
Posts: 9063 Location: San Diego, CA |
greasy125 wrote: wow. what a bummer. I was literally just about to warn you about over tightening it. I have one that's broken just the same. it's NOS, so I just can't bring myself to throw it out. I kid, I kid. You're just a bit too slow |
Posts: 1197 Location: York, PA (the intellectual center of the universe) |
nomadinsiam wrote: Wow, someone would really try to repair that? to do it right, unless it was some ridiculously rare piece the economics of a safe repair would swiftly outstrip any savings over sourcing another piece. |
Posts: 5107 Location: Australa, Mate |
Update on the Headset Saga:
I was able to get a replacement, a used original headset with 3C code written in it. There's a mysterious cutout at the shifter side of the speedo pit. ![]() ![]() ![]() ![]() Closeup at the 3C code ![]() ![]() I cut off the century-old handgrip and removed some mummified hockey tape. ![]() ![]() ![]() The mysterious cutout in closeup ![]()
Posts: 2440 Location: S.Salem, NY |
I imagine that it fits correctly. That clamp is designed to just barely close and bind up an already snug fit. There is no flex in cast alloy.
I am curious as to what the 3C code signifies. No clue on the cut-out but it sort of looks factory in the picture. |
What's the torque setting for the retaining bolt actually? I don't want to overtighten it later.
I don't have the spacific torque but I snug it up to where the headset binds to the column and it doesn't turn with the wheel held from moving, and then just a bit more to set it. There really isn't a whole lot of force on it and if it moves, just give it a bit more. There should be a flat washer and a spring washer under it. Lock washers should not be put against alloy.
The funny thing is that when I looked around the web for pics I found that many of these headsets have the strange cutout but not all.
Kiwi VBC (& 1984 Japanese Smallies) have inserts in the bars for fitting bar-end indicators
I was having the same loose issue with my repro headset. I fixed it using some HVAC stainless tape. Just thin enough to get the headset back on. Perfect. Too late for you sorry but maybe helpful for someone
