@robalatte avatar
GTS 300's
@robalatte avatar
GTS 300's
Does anyone know how to reset the wrench on the 2023 GTS ?
I know how to do it on the GTS Super Tech from Videos but can't seem to find any info on resetting the light for the first service on the normal GTS / GTS sport and Super Sport models..
Scooter emoticon Scooter emoticon Scooter emoticon
@little_karl avatar
2023 Vespa GTS 300 Super
@little_karl avatar
I'm in the same boat. Just did my first service and no information on how to reset the "wrench".
@robalatte avatar
GTS 300's
@robalatte avatar
GTS 300's
I found this on MV, you might try this and let us know. --- Mine doesn't have the light on solid yet (on our green one) and from what I understand from the Super Tech reset procedure, you have to have the light on solid for the reset to work.
Reset Light for normal GTS models, non-super tech:
#1 Turn on ignition
#2 Briefly press mode button to the right until battery charge level appears
#3 Press and hold mode button to the right for at least 10 seconds but less than 15 seconds
# 4 let go and the service icon (wrench) turns off
2019 GTS 300 HPE SuperTech 72,000km
definitely true with my pre-2023 supertech
PX 150 and GTS 300 HPE Super Tech
Here is the procedure at least prior to 2023 and may be unchanged:
@robalatte avatar
GTS 300's
@robalatte avatar
GTS 300's
This is for the super tech and it works. Haven't had a chance to try to reset any of my other 23 GTS models (non supertech) just yet. Hopefully somebody can chime in as to whether the procedure I posted above works on the 2023 GTS Classic, super, and super sport models.
@superdoopergts avatar
2023 GTS 300 Super HPE
This is what I did to reset the service light (remove the wrench icon) on my 2023 GTS 300 Super HPE. On my display, the battery voltage reading is on the left side and these are the steps I took:
1 Turn the switch to the "on" position.
2 Using the joystick, cycle through the options (av. miles per gallon and miles per gallon) until you get to the battery voltage reading.
3 Now, press the joystick "in" and hold it in for at least 10 seconds and then release the joystick. The wrench icon should be gone.
I may have held the joystick in longer than ten seconds but this worked for me. The wrench icon on my bike was solidly lit after doing the 625 mile service and I restarted the scooter twice to confirm that the wrench icon was gone from the screen.
@armedferret avatar
@armedferret avatar
Banger first post, I'm doing the service this week and have been wondering this same exact thing!!
I'll take video and put it up on the ol' facetube or whatever the kids call it these days. Just waiting for the oil to arrive...have all the other bits.
@armedferret avatar
@armedferret avatar
I need to pop to Home Depot and get a new strap wrench (can't find my previous one but I also know it's probably too big for the intended application) which I'll do later tonight, but everything went really well for the break-in service. Gear oil was SUPER clean, engine oil was darkish but nothing shocking/surprising. A few metallic bits in the screen, but that's to be expected upon break-in.
Importantly, I actually remembered to snag a (really poorly made) video of reset. As expected, just tap left on the joystick until you see the battery voltage, then push inward and hold for 10+ seconds. It even tells you that it was "resetted" (that's the second thing I've found that indicates it's truly Italian-designed, along with the need to turn the ignition switch to 'off' when refueling or it takes ages to get the lines back up to the top)
[ Time: 0.0111s ][ Queries: 3 (0.0015s) ][ live ][ 334 ][ ThingOne ]
