SoCalGuy wrote:
This is a head scratcher.
Trying to imagine how you can get "a perfect pressure test -- needle stayed put for 90 minutes" and still get gas in the gearbox.
Seems your leak only appears when the carb's on and the engine's running.
Are you 100% sure you're what you're seeing in the gearbox is gas?
If a clutch or fly seal was leaking you'd have a racing engine at idle. My guess is a bad seal at the carb.
That's why I am losing my mind.
So, no I am not 100% sure that it's gas in the gearbox -- I'm trying not to delude myself (nah, couldn't be!) while also trying to not delude myself in the other direction (what if it is?). Honey colored motor oil is now greenish after about 20-30 minutes of operation over several days. Smells different -- chemical, not gas exactly. But it does not make sense at all that it's fuel unless something changes when the engine warms up. (I also did the pressure test with motor oil over the clutch side bearings before I put the clutch cover back on.)
So, setting that aside. Even if I run it with the choke on, I can't get it to idle slow. It is racing. It does sound like an air leak there. I am sure the inlet pipe isn't leaking at the engine because that was tight at the pressure test. The first thing I did was make sure the carb was seated all the way and the clamp snug.
The other condition that has changed since the pressure test is the exhaust. I used the exhaust elbow with a plug in it for the test; I had to remove that to put the Pollini on, so I cannot be sure that gasket isn't leaking.
Is there anything on/in the carb itself that could cause an air leak? It's the Dellorto 19/19 attached to the inlet pipe. I've cleaned it a couple times over these last few months. Yes I have the little felt packing there, though I think I will check the whole situation over again.
Right now, I thinking:
-check over the carb once more
-run the engine and see if it's not resolved
-if no, pop off the flywheel and check the torque while it's warm
-at some point drop the engine still in the scooter and redo the exhaust gasket, though I'd like to do these in separate steps for science
When I retorque the nuts, should I loosen them a little then re-torque, or just tighten/check them from where they are? (I read an article from this forum about torque accuracy but it seemed to be about higher values.)
