Vespa px 14
Vespa px 14
Ive a vespa px with a malossi mhr 178 , race crank , 24/24 carb , zeus dci and sip 2 with a standard cosa clutch (2014)
Im thinking of putting a vmc 10 spring mollie in , it says it comes with "no drive" ….
If i keep it 21 tooth is that the drive and will it just plug n play (with shaving clutch case)?
Or do i need to buy a 21 tooth drive?
And how would a 22 or 23 tooth drive change the scooter … i like town rides with the odd 1hr out , coffee , 1hr back on twisty B roads
@mjrally avatar
@mjrally avatar
Won't work with the 10 spring. Stock Cosa is 8 spring. You will need a larger clutch cover. The oil channel in the old ones contacts the thicker clutch. Sip sells CNC clutch covers for reasonable costs. Easier than pulling out the dremel.
Definitely try and get the largest tooth in that fits. I believe you have to go 2 up, not 1 so 21 would be 23. That was the case with my 20 tooth, went 22. Confirm with your local garage on what will fit your primary gear.
@gickspeed avatar
@gickspeed avatar
Your 21T Cosa drive gear will fit into the VMC Molle clutch.
You may have to remove some material on the inside of our clutch cover, but not a hard job at all. really, no need to buy another cover.
I would imagine your gearing needs to be something like 22/65 or even 23/65, depending if you matched the transfers in your case to the cylinder.
Vespa px 14
Vespa px 14
Ive googled the removal part already and happy to do that … was about to buy the vmc but it said no drive and because im new to any of this wasnt 100% if i was right in my thinking
Thank you , will buy now but stick to 21drive
Vespa px 14
Vespa px 14
How do you know it wont work? Have you tried? Or just guessing
@mjrally avatar
@mjrally avatar
Haven't tried it. Just guessing off of memory. If Gick says you can, then you can! He knows his shit.
@gickspeed avatar
@gickspeed avatar
The clutch drive gear does not come in contact with the springs. What does come into contact with the spring is the basket and the baseplate; those you cannot switch out and are fairly specific. Get the VMC Molle clutch, add your 21T clutch drive gear, and all will be right in the world.
btw: you can use 21, 22, 23, 24T drive gears from all the suppliers for cosa style clutches.
Vespa px 14
Vespa px 14
Dont worry im always wrong when i guess , thats why i ask silly questions 🫣
Vespa px 14
Vespa px 14
Perfect , thanks for the reply
Any bits i should change while doing this job? Or just remove inside cover bits and put back together?
Jet Eye Master
Jet Eye Master
With an MHR, I wouldn't fit anything smaller than a 22 cog.
Vespa px 14
Vespa px 14
Setting it up so i can try a season on the bsso , that needs to be 21 tooth but will be getting a 22 so i can play around on the road …. My whole set it is for the production class but will be getting a Dellorto VHSH 30mm carb added when i do
Jet Eye Master
Jet Eye Master
BSSO is not 21 tooth on the clutch but on the cluster. You can use whatever clutch and cog you like. If using on the track, it should really be a straight cut primary.
VHSH30 is a complex carb, it's what they use in competition on rotax gokarts.
Vespa px 14
Vespa px 14
I thought i had to keep original 21 tooth drive , 21/35 21/36 and only 4th gear can be changed?
Vespa px 14
Vespa px 14
What it says for production class
Can someone explain please
[ Time: 0.0138s ][ Queries: 4 (0.0037s) ][ live ][ 313 ][ ThingOne ]
