@tomato avatar
GTS 300
@tomato avatar
GTS 300
What The? emoticon
my Tomato started acting bit weird after the winter (is still cold here in Berlin): on idle, while standing in front of traffic light or so, Tomato pushes slowly fwd as if the clutch is engaging for some reason. Of course, one applies the brake and can control this (still...). But this is strange behaviour. This is GTS300 from 2009.
So, please bear in mind the following:
- it has made already 31k KM, so definitely is not in run-in period
- it starts pushing fwd under the driver load, am not speaking of being on centre stand here
can it be that the hinge/joint of the swinging masses of the centrifugal clutch are somehow stuck in "always contact" position? or are the springs which are keeping those mass-pads became too weak or loose?
please advise is this something that is easy for repair (someone with some mechanic skills, but no garage) or something more for the professional help?
⚠️ Last edited by tomato on UTC; edited 1 time
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
Got enough throttle free play?
@tomato avatar
GTS 300
@tomato avatar
GTS 300
hi, thanks for the first idea
How can I check if the throttle play is sufficient? Can I find somewhere the adjustment procedure?
many thanks in advance
There should be a small amount of 'slack' when the throttle grip is fully wound off. If there isn't, adjust the cables.
If the idle speed otherwise seems normal, then changing out the contra-spring in the clutch may well be an answer.
The tape and micrometer is a bit of overkill IMO but Mitch is good
GT 2.4
GT 2.4
I've seen broken clutch shoes do this. The broken one will drag. Usually, this goes from bad to worse pretty quickly though. If it's very cold, there's a chance the high idle circuit is staying engaged longer while the bike warms up. Or, has been mentioned, you are idling off the throttle cable and not the idle circuit.
@greasy125 avatar
@greasy125 avatar
if it came on suddenly, I'd suspect the clutch is dragging for some reason.
when was the last time it had a transmission service?
adjusting the cables for free play is definitely a DIY, the transmission work requires special tools (holders for the pulley/clutch and a torque wrench) and while it is something that you can DIY, it might not be in your best interest to try and tackle it at this stage because you're looking to diagnose a problem.
also, working on the ground sucks.
@tomato avatar
GTS 300
@tomato avatar
GTS 300
many thanks for this. I do suspect that it has to do something with the clutch pads or at least their springs. you are right, the Tomato was not driven enough during the winter, if once a week maximum.
@tomato avatar
GTS 300
@tomato avatar
GTS 300
many thanks, will check this first. let's hope it is just the cable needing some adjustment
Mitch is awesome by the way!
@tomato avatar
GTS 300
@tomato avatar
GTS 300
oki doki, here is the update. Today I used the brakes cleaner as you proposed. Although a lot of things came out (lot of black dust in brakes cleaner fluid), it did not solve the problem.
Am of the opinion that the only viable and remaining cause of the problems is a broken or weakened spring on one of three pads. The hinge of the pad can not be, otherwise I would be having "braking" problem when engine is off. When pushing switched off GTS, absolutely no problems, meaning that pad does not have enough push towards the clutch bell (missing centrifugal forces).
I have seen the Mitch's video on YouTube (many thanks for this) but since I do not have special tools and would need to buy few new (big) sockets) change of only the clutch unit does not seam as a solution.
So, either invest in full driven pulley (inclusive the clutch unit) and do it myself or pay the service to do the change of the clutch only. both same/similar investment Facepalm emoticon
2007gts250ie
2007gts250ie
If you believe a Vespa will long be in your life , I would lean towards the do it you self option. You will gain experience and some spare parts.
@preddybaer avatar
GTS300, CRF1000 & Moto 6.5
@preddybaer avatar
oki doki, news time: after changing the clutch, the problem is not there any more
Clap emoticon
[ Time: 0.0120s ][ Queries: 3 (0.0062s) ][ live ][ 313 ][ ThingOne ]
