I was have discussions with Robbie at Scooter Bottega, and he mentioned that Vespa GTS's with ASR report a lot immobilizer antenna failing.
Vespa GTS Immobilizer antenna which goes around the ignition switch, when it goes kaput, one has to replace the unit. Which is priced at around $150 retail.
The antenna is a sealed solid state device made by Magneti Marelli. Being a solid state device the only time something will fail is when it overheats and loosens the solder in the circuit board or there is a high current draw at the time the device is turned on or off, wiring harness/connectors loose/corroded, etc, can possibly cause failure.
So if the immobilizer antenna fails is there a way to repair and fix it or one has to replace the unit. I wonder if it anyone has managed to repair a immobilizer antenna?
