2006 LX150
2006 LX150
I recently watched some of Mitch's videos on YouTube and on the particular scoot he was working on, same as mine, he yanked out and tossed the evap system, saying the bike would run better. While this was intriguing, can anybody elaborate on this?
Will this have any effect on how difficult it is to get fuel in the tank without spilling?
He did the process quite rapidly and I didn't get all the steps. Is this a good thing or a bad thing (and no comments from acolytes of The Church of Climate Change, please).
@marret avatar
2016 GTS300 ABS
@marret avatar
2016 GTS300 ABS
This subject has many threads that an "evap" search will find. Jess did a lot of work on search functionality. Suggest you become familiar with the search function.
Try this article for newer 300s:
2021 Vespa 300 GTS Super EVAP Removal
Try these links:
DIY? - EVAP Removal LX 150i.e.
LX150 Complete EVAP System Removal
2006 LX150
2006 LX150
Thanks for that. It was much easier asking the hive! Anyway, now I'm on a roll and will use the search. Off to the grodge to fix stuff! Thanks again.
@jakem avatar
Vespa Sprint Sport S 125cc
@jakem avatar
What is the purpose of the EVAP? Is it emissions related?
@marret avatar
2016 GTS300 ABS
@marret avatar
2016 GTS300 ABS
Yes it is emissions related. The evaporative emissions system (EVAP system) is designed to capture hydrocarbon vapors (fuel vapor) and recycle it back into the engine intake to be burnt as part of the normal fuelling process.
BV250, BV500
BV250, BV500
It's there to capture evaporation from the fuel tank and reroute it back into the intake system of the engine. And yes, it is emission related.
There's no need to remove it if you don't have any problems.
However, if you overfill a few times in succession, you can get a situation where the charcoal canister gets clogged with liquid fuel rather than just fumes. This can lead to the tank not venting properly, eventually leading to fuel starvation.
If you suspect this, remove the fuel cap - if there's a gulp of air going into the tank then that's your problem. The correct thing to do is to swap the canister for an unclogged one, and let the clogged one evaporate away over a few days - but this is a right royal pain in the arse to do. If you're removing the canister anyway, just strip the lot out and have done with it - remembering to add some extra line to the fuel vent pipe so it vents up, across and then down the left-hand side. This avoids spillages if you tip over.
The scooter will no longer 'moo' as it cools down, but if you put it away in a garage while hot, it will stink the garage out with gas fumes.
@miguel avatar
@miguel avatar
There's a mechanic I follow on YouTube that focuses on older BMWs like my 2001 R1100RT. He has a number of videos on why you should remove the EVAP charcoal canister. Here is a short one showing that even on low-milage bikes, there are enough charcoal particles that can clog the fuel injectors.
He has other videos showing more details but I'll let you explore those on your own.
Miguel
@vintagescooterdude avatar
2006 GT200 2009 Genuine Stella
I have removed the EVAP system completely on every motorcycle I have ever owned. On the Vespa the components were so difficult to get to that I just left them in place, but disconnected and plugged everything. I fill my tank all the way to the top of the filler neck. If you do that, liquid gas is going to get into the EVAP cannister and cause starting/running problems. I was having starting/running problems with a brand new Kawasaki motorcycle once, and the dealer told me to just fill the tank about 3/4 full. That was ridiculous. It was a 750cc engine and a 2.3 gallon tank. I completely removed the EVAP system, along with the PAIR system, and the bike started and ran great with a completely full tank.
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
Here in Europe, considering the negligible share motorcycles have on fuel vapour, we do not have EVAP systems on motorcycles, so nothing can go wrong with it.
I think I read somewhere that the GTS 2023 in Europe has the evap system (might babe been when they went to E5?). But not sure and too lazy to double check right now 🍺
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
Here is a video on how to remove it on a Vespa GTS 300
https://www.youtube.com/watch?v=lxGyZ_GzdIQ&t=15s
2006 LX150
2006 LX150
Thanks for all your input guys. I really appreciate your patience and hope I don't annoy you with too many more odd questions!
@dooglas avatar
@dooglas avatar
Exactly right. No point in eliminating the EVAP system to address a problem you don't have.
And to answer the OP's original question - NO. Though there are a number of discussion threads and plenty of advice on this site about how to avoid overfilling.
[ Time: 0.0110s ][ Queries: 3 (0.0044s) ][ live ][ 313 ][ ThingOne ]
