plantguy wrote:
After catching myself up on your build more completely, slightly off-topic question for you. If you were to avoid the Mazzu cranks, for a largeframe build is there one manufacturer that stands above?
Not that I'll be getting anywhere near the upper limits you were, but still...
I'm now running a Quattrini crank in the Smallstate. For the P200 build I'm contemplating, I'll probably go with an Uncle Tom 62mm bell crank. Basically, high end cranks run $400-600, versus stock-grade cranks for ~$100, and more normal "performance" cranks at ~$200. You have to learn the brands, and can pick up a lot by just watching the components that other tuners are the level you're (trying to be) at. Then, look at the spec's for those parts and you can extrapolate from there.
plantguy wrote:
Back on topic - I am diving deeper into the math and building an online excel sheet that might be helpful to others. Port-timings in Jennings is very interesting. I captured a few paragraphs (screenshot) that nicely line up with what a lot of you experienced wrenches have been guiding us noobs to.
Still working this out and will hopefully get measurements dialed in on the engine tomorrow to help put it into context.
SoCalGuy was working on this exact topic over the weekend with CM2 and I helping(?) out via text message. While a lot of that info is, as Jack said, based on the limits of 1970's materials science, it still fundamentally applies in determining how a particular change will impact the shape of the power curve.
First off, there's the basic math of determining port timings from port measurements. I have a sheet which I found that does that, plus I built speed and power requirements. The power requirements need some tuning, but the gearing calculator is useful, at least.
You should be able to download a copy of it
here. It uses
LibreOffice for the more interesting (i.e. macro's) bits, but the basic calc's all work if you import into Excel, too.
I recently started adding some new functionality to it that maps port timings to expected peak power RPM's, but it's not ready for prime time. It requires port width, not just port height, which means generating a proper port map to measure from.
And if you want to get really serious, you can plop down the cash for actual software. Patrick (OopsClunkThud) uses EngMod2t, but I haven't ever quite pulled the trigger on that...yet.
