Mon, 10 Apr 2023 17:07:05 +0000
2008 MP3 400
2008 MP3 400
Mon, 10 Apr 2023 17:07:05 +0000 quote
Symptoms:
Bike is on the stand
Turn on the ignition; front suspension tilt-lock warning lights rapidly flickering, NOT steady flashing.
Tilt lock switch does nothing.
Engine starts OK.
Replaced blown 20A fuse #4; problem persists.
Suggestions?
Mon, 10 Apr 2023 19:39:23 +0000
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Mon, 10 Apr 2023 19:39:23 +0000 quote
red or orange flashing?
Mon, 10 Apr 2023 20:43:22 +0000
2008 MP3 400
2008 MP3 400
Mon, 10 Apr 2023 20:43:22 +0000 quote
Both the system warning light and the system failure warning light are rapidly flickering, not just flashing.
Tue, 11 Apr 2023 03:50:00 +0000
2009 mp3
2009 mp3
Tue, 11 Apr 2023 03:50:00 +0000 quote
Fuse 4 also feeds fuse 11 and i think others sounds like a high resistance joint some where but check all the sub fuses for corrosion.
Tue, 11 Apr 2023 21:19:54 +0000
2008 MP3 400
2008 MP3 400
Tue, 11 Apr 2023 21:19:54 +0000 quote
I disconnected the battery, then pulled, inspected and put back all 10 fuses as suggested; all were good.
Turned the key on and the problem had disappeared and the tilt lock functioned normally.
I don't know why this did the trick.
I should mention (to my embarrassment) that this began when I installed the battery. Having cross connected it in dim light a few years back I was very careful to identify the battery terminals this time and place the correct leads next to them.
I then saw that the battery had to be turned 180 degrees to fit it. So, I turned it, and thanks to a senior's moment brain fart, attached the ground wire to the adjacent (+) terminal and then when I touched the other wire to the other (-) terminal...SPARK!!
I just stood there in utter disbelief that I had just "done it again".
What a way to start the season!!!
Wed, 12 Apr 2023 06:34:43 +0000
2009 mp3
2009 mp3
Wed, 12 Apr 2023 06:34:43 +0000 quote
Don't bother buying any lottery tickets I think you have used up all your good luck. Removing and replacing the fuses would be enough to break down a HR joint. It may happen again but at least you know where to start. Some years ago I reversed the battery connections on a Volvo I owned but wasn't as lucky as you it blew the fuse in the ABS controller and I later found out the whole printed circuit board was a throwaway to my great expense'
Sun, 07 May 2023 22:20:53 +0000
2008 MP3 400
2008 MP3 400
Sun, 07 May 2023 22:20:53 +0000 quote
For what it's worth I discovered my hidden fuse had also blown, so my battery wasn't charging.
  DoubleGood Design
[ Time: 0.0312s ][ Queries: 4 (0.0101s) ][ Debug on ][ 283 ][ Thing Two ]
