If you bought a ~10 year old GTS with low mileage but no service history, what would your To-Do List look like?
Posts: 45848 Location: Pleasant Hill, CA |
Atypical Canadian
Posts: 2319 Location: Toronto, Canada |
I bought a much older GTS with no service history and only 1200 miles for a fraction of the price of a new one.
REPLACE ALL FLUIDS Brake fluid 7 ways to tell if motorcycle/scooter tires need replacing CHECK AND/OR REPLACE BATTERY How to test a battery At this point you're probably going to want to look at your owner's manual, under SCHEDULED MAINTENANCE or PERIODIC MAINTENANCE or whatever Vespa/Piaggio calls it. Some examples could be: Replace belt and/or rollers
Positive
Atypical Canadian
jimc wrote: Change tires, belt, oil, coolant, battery, bleed brakes with new fluid. Then ride.
Positive
2015 Sprint 150, 2018 GTS 300
Posts: 894 Location: SoCal |
Wow, mate you are lucky you have a bunch of people who will share knowledge that sure you could get but the effort would be a bit more than popping on to the forum.
I don't know if chatGPT would be able to answer that question with the same level of detail. So if you follow the advise given, you are most likely going to have a Vespa running smooth and properly maintained thereafter. |
2006 GT200 2009 Genuine Stella
Posts: 297 Location: Chandler, AZ |
Basically do everything on the list except the valves and spark plug. I replaced the belt on a 10 year old GT200 with 1800 miles on it. It looked fine, and I kept it. I don't trust CVT belts. I was stranded on another scooter in 115 degree heat with no shade or water for several hours once because of a shredded belt.
Atypical Canadian
VintageScooterDude wrote: Basically do everything on the list except the valves and spark plug. I replaced the belt on a 10 year old GT200 with 1800 miles on it. It looked fine, and I kept it. I don't trust CVT belts. I was stranded on another scooter in 115 degree heat with no shade or water for several hours once because of a shredded belt. Also... who said anything about spark plugs? |
Motovista wrote: How low is really low mileage? So far I've just changed the oil and the front shock. Tires look OK. This is how my list looks currently: Belt + Sliders Coolant Brake fluid Rear shocks valve clearance closer to the 3k mark I hadn't planned on gear oil but I guess that should go on the list too |
JenniferJupiter wrote: I would absolutely replace the fuel lines. |
jimc wrote: Why change the shocks? The rears are bottoming out on bumps. |
adri wrote: Why not valves if they are due? Especially given that we don't even know how many miles the bike has? Also... who said anything about spark plugs? Engine oil is by far the most critical, but all fluids are important. I probably didn't need to replace my belt, but after having had a belt with only 4000 miles on it fail under dire circumstances, I wasn't going to take a chance. |
Posts: 4718 Location: Twin Cities, Minnesota |
personality wrote: Tires look OK.
Positive
personality wrote: 2,000. fwiw I said low, not really low. So far I've just changed the oil and the front shock. Tires look OK. This is how my list looks currently: Belt + Sliders Coolant Brake fluid Rear shocks valve clearance closer to the 3k mark I hadn't planned on gear oil but I guess that should go on the list too Any idea how it was stored? |
JKJ-FZ6 wrote: I would replace the tires if they're ten years old. Check the date codes. |
personality wrote: They were shot all around. The handling felt really squirrely from the front end, it was a bit scary to ride. I went with a Bitubo in the front and it made a huge difference. The rears are bottoming out on bumps. |
Atypical Canadian
jimc wrote: That's strange for a low mileage Vespa to have shot shocks. But hey, you changing them so all good. Makes you wonder if someone rode the heck out of their Vespa, and then bought a used low mileage cluster on ebay, and swapped that in. One of my GTS is 17 years old, original socks are still in great shape, only 1,200 miles. Another is 17 years old with 11k miles, still in great shape as well... |
Atypical Canadian
VintageScooterDude wrote: OP said it had low mileage. Valves are a mileage related service, and since this GTS is at least 10 years old, it is not an HPE. Valves on non HPE models do not require service until 12,000 miles. The spark plug is also a maintenance item, but unless there is a problem that could cause damage to the plug, like an overly rich mixture, they are also mileage related. I bought my 10 year old GT with 1800 miles on it, and while I did just about everything else (I did go ahead and wear out the original tires that were in perfect condition) I didn't touch the valves or spark plug till 12,000 miles. All four valves were within spec, though a couple were pretty close to the edge. The plug could probably have been cleaned, regapped, and used for another 12,000 miles. Engine oil is by far the most critical, but all fluids are important. I probably didn't need to replace my belt, but after having had a belt with only 4000 miles on it fail under dire circumstances, I wasn't going to take a chance. |
Posts: 8321 Location: Batmania aka Melbourne, Aus |
jimc wrote: That's strange for a low mileage Vespa to have shot shocks. But hey, you changing them so all good. with a 2nd hand bike some may feel this is worn out but some others may say oem shocks are too soft |
Posts: 5464 Location: Jacksonville, Florida. Weaverville, NC |
fergy wrote: Squirrelly handling could also be tire or tire pressure related. They feel different than a motorcycle. Bill
Positive
Posts: 1716 Location: Vermont |
personality wrote: 2,000. fwiw I said low, not really low. So far I've just changed the oil and the front shock. Tires look OK. This is how my list looks currently: Belt + Sliders Coolant Brake fluid Rear shocks valve clearance closer to the 3k mark I hadn't planned on gear oil but I guess that should go on the list too |
wbdvt wrote: Perhaps the OP did not check the shock settings as they come set at the lowest setting. This could cause bottoming out and not a good ride. This is definitely not my first scooter and the front shock improved the handling a great deal so I am happy with the decision. |
Posts: 12750 Location: Fond du Lac, Wisconsin |
personality wrote: The stock rears are adjustable? No big deal on the replacements at this point....there are people who change out the shocks almost immediately after buying new...as long as you're happy! |
adri wrote: 1,200 miles per year for ten years = low mileage and due for a valve adjustment I actually do not recommend letting any motor vehicle just sit for years without being touched. Not even a few months. I store most of my 2 wheelers during our long 115 degree F summers, but that doesn't mean they just sit. I drain ALL of the ethanol out of the fuel system and pour in a gallon of TruFuel. It has a 2 year life span. I keep battery maintainers on them. I usually start them up and warm them up every couple of weeks. I move any tire sitting on the floor to a different position. I keep the tires properly inflated. I spin the wheels to keep the brakes from locking up, on bikes with manual transmissions I put them in gear and use the clutch. Things that are designed to be moved need to be moved. Engines that have sat for a long time without being moved can sometimes have a dropped valve after being started. That's because the valves weren't moved for so long they stuck in the guides. The engine may start and run, but if the valves are tight in the valve guides, one or all, but it's usually just one, may stick open, and get hit by the piston when it comes back up to TDC. A valve adjustment won't fix that. You have to remove the valves and clean the stems, and replace the valve guide seals. Once an engine has run for a couple hundred miles, a dropped valve becomes extremely unlikely. |
Atypical Canadian
VintageScooterDude wrote: 1,200 miles PER YEAR for ten years = 12,000 miles, and it is due for a valve adjustment. 2,000 miles TOTAL means another 10,000 miles before it is due for a valve adjustment. |
