garncarz wrote:
Buy a new: 2nd gear, cruciform and 2.5mm spacer. Put it back together and ride it.
We know someone has been working on the gearbox in the past due to it having a second oversize shim installed. Who knows what else has been changed out?
Using the gear thickness chart posted by SaFis, measure all your gears center sections, not overall height, and compare to the chart. This will help you determine if you have mismatched gears! Another option would be to call Scooter West or Scooter Mercato and see if they can provide dimensions for the correct gears and compare that with what you have.
If you end up replacing gears, don't order your spacer until you have your new gear stack fully assembled. Then take your gear float measurement and see what your clearance looks like. You may be surprised that your 2.4 mm spacer is fine especially if the new gears are thicker than what you are replacing.
I would also highly recommend you install your axle shaft with new cruciform and no gears to verify cruciform alignment for each gear. Verify that cruciform position is centered on the wear marks on the axle shaft for each gear. Verify batwing on selector box is correct for each gear. If the cruciform doesn't line up with the wear marks, something is wrong with the gear selector box, selector rod, selector rod washer or all the above. The cruciform can be adjusted slightly towards the sector box by installing shims between the selector box and engine case. The cruciform will move by the thickness of the selector box shim. I have attached pics of this test from my build. The cruciform end was painted yellow for clarity. I hope this helps. It's important to confirm your setup is correct now that it's apart instead of just throwing parts at it.
Hec
