PX Vespa 125
PX Vespa 125
Okay there l am just wondering about doing my front brake caliper ! As I keep getting a problems with it , is there a budget replacement part l can use ! Or is it only like for like on the vespa px !! Will the LX or et4 one fit in ! Any advice most welcome soulmate's stay lucky you guys peace and love soulboy74 🏴󠁧󠁢󠁥󠁮󠁧󠁿☮️
PX150E
PX150E
Depending on your exact model year PX, you should be able to disassemble the caliper, clean up all the parts, and reassemble using one of the kits below:
https://www.sip-scootershop.com/en/product/gasket-set-sip-brake-caliper-front_56409000?q=front%20brake%20caliper%20seals
https://www.sip-scootershop.com/en/product/gasket-set-sip-brake-caliper-front_56409100?q=front+brake+caliper+seals
The second kit, of course, costs more because a new set of pistons is included. If you are not interested in refurbishing your caliper, or if the caliper is severely corroded and pitted internally where the seals slide, then the only other solution is to replace the entire caliper.
[ Time: 0.0093s ][ Queries: 3 (0.0030s) ][ live ][ 313 ][ ThingOne ]
