@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
After the excitement of ROM, the Quattrini motor swap by Chandler and all the go fast shenanigans, when I brought Red home he seemed sullen and distant. I knew something was amiss.
Yes, the motor I built several years ago had a developed an air leak and I planned to replace the seals. But there was more. I sensed an emptiness, a longing, a restlessness. Red had experienced the joy - and terror - of insanely high horsepower in San Luis Obisbo. He had shot past other scoots at 70+mph on Los Osos Parkway. He'd heard and felt 10,000rpm in his belly. He knew that there was more to life as a smallie than just putt-putting around the neighborhood. It was obvious things would never be the same.
Soooo, while the engine was on the bench, did a little old school tweaking to the Polini 130.
- 2mm spacer under the barrel
- Shaved the top to 1mm squish
- Raised exhaust ports
- Opened intake
- Cut a few mm off crank and flowed
New numbers:
Ex: 185°
Tr: 131°
Intake: 170°
All buttoned up and holding pressure
@108 avatar
V range 50s
@108 avatar
V range 50s
Exciting enhancements.
Definitely good therapy.
@charlieman22 avatar
Nedminder
Nedminder
Hey!
That's some good therapy.
I mean, red's exhaust is never gonna be the same - if u know what I'm sayin'.
Those are some far sportier numbers.
Love that the leak turned out to be addressable without split.
How does it run?!
VNB VSC VMA VSX - o9c vbc vmb
Nice!
Ya treating red right.
@chandlerman avatar
Lucky
76 Days Since Last Explosion
Lucky
@chandlerman avatar
Red is a happy little scoot and deserves to be out tearing it up around Southern California, not hiding the shame of a leaky exhaust.
I'm just glad I was able to do my little part to get the ball rolling. Just setting high expectations goes a long way.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Haven't run it yet, but I like the numbers.
Prepped for surgery
Prepped for surgery
This much came off crank
Opened intake a smidge
Old skool decking: shaved ~2mm using angle grinder + belt sander + final leveling by hand. Shoulders still sore.
There a gasket sandwiched in there somewhere between the goop
Dent masking & new delinquent persona
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
[quote="SoCalGuy"]
Ah the S.L.O. Life! I used to live in San Luis Obispo 1987-1989. In fact I worked in Los Osos too! I went to Cuesta CC chasing Cuesta Betties and Polly Dollies! Some fun times! Then I got serious and went to UT and got a degree in Mechanical Engineering. I don't think I could of finished school in S.L.O. with all the distractions! Prior to that I grew up in Lompoc (Vandenberg Village). I miss the Central Coast!
Hec
Nedminder
Nedminder
Wait - you are aware that you know a guy with a mill and a lathe, right?
@qascooter avatar
@qascooter avatar
I'm excited to see the disc brake that Red got! Razz emoticon
Jet Eye Master
Jet Eye Master
Nice job on the crank. Cylinder lots of work but worth it. Port timing should keep red happy. Expect strong mid, maybe 8500rpm peak power, with a long overrun, which might make 10k.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Ok, to fill in the group, said guy graciously offered to deck it for me with his fancy-pants mill, which I appreciated. However, it's an old cast iron barrel and hardly worth the wear on his machines. Besides, I wanted to see if it was doable by the average Joe with marginal skills (i.e. me) with some hand tools and determination. It is, but like Jack said, it's work.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Red didn't get a disc brake.
But Uncle Chandler gave him a snappy new short stoke throttle pulley as a parting gift. Thanks CM.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
I figured it was the least I could do. It's also red, btw. And very snappy.
@qascooter avatar
@qascooter avatar
Most Excellent!
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
I did it old school, with a belt sander also, bought a belt with a high grit number. Something that should have been way to fine 600 grit. Gave me a bit of time to be able to rotate head while sanding. I think I'd go 800 or higher if I do it again that way.
Wait, people are using belt sanders and angle grinders to mill down cylinder heads? Interesting.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Can't imagine using a grit that fine. It must've taken days.
I started with an angle grinder and a diamond wheel, then switched to the belt sander with a gnarly 30 grit belt. That took about half an hour.
I put a straight edge on it and it looked pretty level, so I bolted it on and gave it a pressure test. Not even close. Bubbles everywhere.
Out came the plate of glass and 60 grit (shown in the pic). An hour later - maybe two - it was nice and flat.
Quite the workout. But yep, very doable.
@modkuo avatar
'79 P200, '74 VBC Super, '77 P125 Project, 1978 Rally 200
@modkuo avatar
wow dude, having time to get serious is amazing. Im stoked to see all that is happening these days...ive been gone missing.
Blue is ready for a refresh and the P is getting a 210 upgrade very soon. lets reconnect broskin...Post-pandy work-life has been out of balance...and has been seriously interfering with scooting, but the table is set..and I have a new house and garage as well.
see you soon MVP....and MV peeps in general...
Modkuo
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Modkuo
He's alive!!!
Nedminder
Nedminder
I can't believe the outcome.
I can hardly sand the end of a bolt flat when I cut down it's length.
Remarkable.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Remarkable.
A dedicated act of perseverance, attention to detail, and a bit of olescooterboy luck! Great work Clap emoticon
2007 Stella 225
2007 Stella 225
Wasn't bad, using a 4"x36" belt sander, I set the head on belt and rotated it while sanding. Didn't have to use any down pressure. Kept sealing surface fairly flat. Finished up with a piece of glass, with wet and dry.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
I lapped down several DR heads when that was still something I ran/did. I went with the wet/dry paper taped to glass method. My usual rate of progress was about 1mm per hour.
I still have a collection of DR heads with the new height written on them in paint marker, not that I'd ever normally use them.
This is also why I heavily prefer top ends with inset heads. You just add head spacers to get your squish. The fact that they tend to seal really well is an added bonus.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Ok, you're talking about a head, which is softer aluminum.
This is a cast iron cylinder. 800 grit would barely scratch it!
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Engine's in. Fired it up and it sounds good.
Should be rolling this week.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Yeeeeessssss!
Where's the First Start Video? Them's the rules, you know!
Looking good!
Nedminder
Nedminder
It's appropriate to show shinny scooter porn pic like that for Red, after his "spring break" excursion with uncle CM.
X2 ok n the vid - or head up here for a coastal ride!
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
I tried to keep us out of any "Scooters Gone Wild" videos, but am pretty sure I failed miserably on that count.
We had a really good time, though, even if it involved taking rides with strangers, winding up in strange parts of town, and even a little unplanned surgery.
We came back with all our Kidneys, though, which is my personal bar for success.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
I'm surprised he didn't marry a stripper or come home with a face tattoo.
Nedminder
Nedminder
Apropos to show shinny scooter porn pic like that for Red, after his "spring break" excursion with uncle CM.
X2 on the vid - or head up here for a coastal ride!
⚠️ Last edited by charlieman22 on UTC; edited 1 time
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
It was an easy annulment, so I wasn't going to say anything until you mentioned it.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
chandlerman wrote:
Yeeeeessssss!
Not YouTube savvy… I'll send u a clip if you want to post it
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
I can do that. I'll text you a link you can upload it to and then post it from there.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Red's first re-start...
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Lordy Mama!
Just took the little devil out for a spin around the neighborhood, and holy cow, big difference. Lots quicker and pulls hard.
Didn't open it up and forth yet. It'll be fun to see if it gained some top speed.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Yasssss! Happy, this makes me.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Yah, good stuff. Still smiling from yesterday's romp. Red's a genuine light-to-light bandit!
Probably going to blow the clutch or twist the crank at some point, lol, but we'll deal with that downstream.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
If you can't kill a stock clutch, you're not really tuning. Razz emoticon
[ Time: 0.0235s ][ Queries: 5 (0.0075s) ][ live ][ 313 ][ ThingOne ]
