@teslawrld avatar
2023 Vespa GTS SuperTech
@teslawrld avatar
So I just washed my scooter for the second time the other day and I remember shortly after it had a warning sign saying key not detected but then that went away and now when i try to start my 2023 gts I have to put the key very close to the wifi logo on the left side of the scoot in order for it to recognize my key. Before I just needed to have it in my pocket for it to be recognized. Does anyone know why this is? Did I break something with the water I used to clean the scoot? I hope not 🤞
Vespa GTS 300
Vespa GTS 300
Did you deactivate your keyless-key?
Press the bike finder (upper button) and within 5 seconds also the seat opening on the remote control, keep BOTH buttons pressed until the color of the LED changes. Then try again if the remote control works.
"ACTIVATING THE REMOTE CONTROL
To activate or deactivate the remote control, press the Bike Finder button "A" and within 5 seconds also the seat opening button "B" until the color of the LED on the remote control changes.
When the LED on the remote control turns green, the authentication of the "Piaggio Keyless" system can be performed. If the LED turns red, authentication cannot be performed.
If the remote control is not recognized, it is recommended to repeat the activation and authentication procedure. If the lock persists, it is necessary to make a new attempt with passive recognition."
Source: user manual
@teslawrld avatar
@teslawrld avatar
Source: user manual
Ok thanks I'll try that
@teslawrld avatar
@teslawrld avatar
Source: user manual
It worked! I guess the water must have somehow deactivated my key lol but all good now it works!
Vespa GTS 300
Vespa GTS 300
Great!
Why would washing have deactivated the keyless key? Did you also wash the keyless key / put it under water?
I rather think that you accidentally pressed both keys at the same time when the keyless key was in your (pants) pocket.
@teslawrld avatar
@teslawrld avatar
Great!
I don't know but I do have them in my back pocket a lot so that could have been it! The weird thing tho was my Vespa said key not detected in red right after I had got done washing it when I was driving away when the key fob was still in my back pocket!
Vespa GTS 300
Vespa GTS 300
Maybe you bent over to wash or sat down for a moment, keys in your back pocket and 5 seconds later it happened.
Deactivated key is by the way identical to empty battery of the remote control... Keyless-Key must then be held close to the left side.
[ Time: 0.0074s ][ Queries: 3 (0.0018s) ][ live ][ 313 ][ ThingOne ]
