'81 Vespa P200e, '85 Vespa PX125e, 1985 T5
Hi everyone. I have a p2 that I'm trying to align the fork w the headset.
I can't seem to get the headset aligned properly.
Is there a trick to doing it? Or is it simply guessing?
I think it's right but when I take the fork from lock to lock the headset hits the leg shield trim on the left side.
the one time I got it right, the headset was crooked when I was riding the bike. Lol.
A bit frustrating to say the least.
Thanks for you help.
@charlieman22 avatar
Nedminder
Nedminder
Nelluch,
If the headset is properly aligned with the wheel - but still hits the leg shield - perhaps your steering stop - rather than the alignment - is the issue.
I don't know the scoots well - so someone with more insights can give you the low down on options for the stop - but I think its more the latter than the former.
@colinbelgium avatar
VBA1T/Px200 iris/VNB6t
Did you take the bearings out from
The chassis ? Could be the bottom race not properly inserted, then the fork is too low, then the headset also.
What is your distance between the mudguard and the leg shield ? Picture ?
@245luigi avatar
1960 Vespa Allstate 788.94494 (totalled); 2012 & 2011 Kymco Like; 2005 Stella, 1979 P150X (stationed in Sicily)
@245luigi avatar
I rode around with a ratchet and torque wrench and adjusted until the headset was straight while going straight. The mudguard isn't centered so tough to do by eye
charlieman22 wrote:
Nelluch,
Possibly. I can double check to verify. Thank you!
I did remove the bearings then reassembled. I can send a picture. But I don't think this is the case.
Thank you.
parallelogramerist
parallelogramerist
yer fork stops are bent. Remove the horn casting and pound them back into the original shape.
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
Sure sounds like it. Scooter West has a nice video explaining this.
Here is a 60 second clip of the video. You will probably want to watch more than 60 seconds.
https://youtube.com/clip/UgkxVKDdH1QSOUUxBfYG3lsr0eEUFlsZqsqI
Hec
Thanks everyone. Great input here. I'll take a look.
Photo as promised.
I think the issue is solved. I knocked the steering stop back into shape.
But I'll add a photo in case I am over looking something.
Thank you everyone!
[ Time: 0.0086s ][ Queries: 4 (0.0028s) ][ live ][ 313 ][ ThingOne ]
